PDA
View Full Version : Racing and High Performance
Pages : [1] 2 3 4 5 6
  1. Port Sizes, Port Matching, Intake Bolt Alignment Questions
  2. Another stroker small block
  3. BBO Holley Street Dominator Manifold Bolt Holes Do Not Line Up
  4. CNC Ported Edelbrocks
  5. Help tuning in northwest ohio
  6. Dyno Testing the Big Block Olds Part 11
  7. Oldsmobile for HPDE roadracing
  8. Good non return fuel pressure regulator?
  9. Smallblock header recommendation
  10. 330 Stroker (402ci)
  11. Rocker Geometry - "Ford" Geometry vs Olds
  12. lifter preload
  13. Fan clutch
  14. Which vacuum port -
  15. Oil to coolant sandwich adapter cooler
  16. Electric fans on radiator
  17. Pregessive ignition HEI
  18. Q4 Head From Factory Race Dept.
  19. Rpm intake 1969 cutlass
  20. Merrill Wi Ice Racing 1320video URL
  21. 500hp 455 combo that will live
  22. Testing Session is a Disaster
  23. Built 350 surging under load
  24. H pipe or X pipe, do they actually always add power?
  25. Oil Volume vs Oil Temperature
  26. PDD Ported Gen3 Edelbrock Heads
  27. Dyno Testing the Big Block Olds Part 10
  28. Petronix Distributor
  29. Vacuum Testing Cylinder Heads
  30. Rebuilt engine rapping noise solved.
  31. February Dyno Testing Session
  32. Brainbeau 66’ questions
  33. F1 level piston design
  34. New headed 350
  35. Dyno Simulation Software
  36. exploring Oldsmobile performance ideas
  37. Dyno Testing Anniversary and Intake Manifolds
  38. Next Dyno Session
  39. 495 build any ideas on vacuum??
  40. Factory windage tray? Aftermarket tray? Or none?
  41. Dyno Testing the Big Block Olds Part 9
  42. F headed 455
  43. Need an oil pump pickup for a 9.25 inch deep pan.
  44. Anyone going to Cecil County this Saturday?
  45. Edelbrock 04b
  46. Overpowering Brakes
  47. Dyno Pull
  48. Carburetor at WOT
  49. 557ci Rocket Build
  50. Dyno Testing the Big Block Olds Part 8
  51. D. Bares 68 H/O D/SA
  52. Lowering compression on 455 for centrifugal supercharger
  53. One of the dyno pulls
  54. Let’s start a Kings of Olds power list based on HP per Cubic inch.
  55. 10" torque converter stall speed
  56. Small block stroker crank update
  57. 403 Build/Iron heads
  58. Coppercutlass 2025
  59. Dual Port Manifold
  60. Waking up my 81 cutlass
  61. 60ft vs mph 1/8 mile
  62. "Modern Ring Packs"
  63. Coating companys feedback?
  64. Stainless steel valves and iron guides
  65. Low compression 350 Olds GT/JA 170 factory HP 9.86@135
  66. 1.72 rockers with a W31 cam?
  67. Dyno Testing Update
  68. First stroker SB with new style 4.00” stroke crank
  69. Intake gasket replacement /raising compression
  70. Dyno Status
  71. 1000 HP NA Big Block Oldsmobile BTR
  72. Dyno Testing the Big Block Olds Part 7
  73. Stock intake capability
  74. Heat Crossovers Filled
  75. 1970 W-30 Engine Idling
  76. Stock Appearing
  77. Getting Ready for the Next Round
  78. Flywheels
  79. My Exhaust Adventure
  80. Collection of JerryW's Big Block Oldsmobile Dyno testing documents.
  81. Performance parts suggestions
  82. Engine Block Question
  83. Crankcase evacuation system to exhaust
  84. Dyno Testing Status
  85. Headers for 69 Cutlass
  86. Big Block Olds Dyno Testing Part 1
  87. Next Big Block Olds Dyno Session Drawing Near
  88. Dyno Testing the Big Block Olds Part 6
  89. Anybody looking for a diesel block?
  90. Time Slips - Race Day at OCA Nationals 2025
  91. New size/spec Mahle piston kit
  92. Lets See CKP's 650 HP 455 Bracket Builds
  93. Homebuilt 455 Dragstrip Results
  94. A Challenge to Jerry W.
  95. Racing at Bowling Green
  96. Camshaft Poll
  97. Can stock J heads make the same power as stock C’s
  98. Single vs Dual plane
  99. What's harder on an engine dyno pulls or 1/4 mile pass.
  100. Dyno Testing Part 7
  101. Dyno Testing Part 5
  102. Dyno Testing Part 4
  103. A Day Testing
  104. W30 vrs W31 Camshaft
  105. Rocker Ratio
  106. Sanderson center dump
  107. Which Headers will fit a stock 1971 350 4bbl?
  108. Where can I buy new intake manifold gaskets?
  109. Is this a composite distributor gear?!
  110. Theoretical 425 build
  111. Informational - Edelbrock Small Block Oldsmobile Pre-orders!
  112. cracked oil pan
  113. 350 Hi Vol water pumps?
  114. 455 Dyno test 3
  115. Using Ford pedestal rockers
  116. Ignition points what brand?
  117. Brand new roller lifter no bueno
  118. W31'S cam shaft advance, retard?
  119. Oldsmobile factory race info
  120. Pure stock drags, what gear
  121. Any idea what camshaft this is?
  122. Engine Diaper
  123. Supercars Unlimited cam specs
  124. Cool 454ci 350 "D" block on the Dyno
  125. Lohnes on Funny Cars (442 Much)
  126. 9" gm conversion rear end questions
  127. 1988 toronado trofe fuel feed lines
  128. K-Motor Fitting
  129. 1970 Olds 98 Turbo
  130. The W43 dyno session
  131. Auto Cross Video Anyone here building one
  132. Camshaft RPM range
  133. High compression 455
  134. 2025 Oldsmobile Nationals Drag Race Registration & Info Thread
  135. Dyno testing performance parts on a stock 455
  136. How did YOU install your Aluminum Radiator?
  137. Ford Windsor roller rockers?
  138. New Edelbrock small block Oldsmobile cylinder heads!
  139. Comp Evo hydraulic roller lifters
  140. And we thought the sound made it worth it!!
  141. What intake
  142. IgntionController
  143. Aluminum Head Question
  144. Something a little different
  145. Piston to valve clearance question Edelrock heads xe284 cam
  146. 065 Edelbrock intake Anyone?
  147. Anybody else see this slick intake?
  148. Aftermarket timing cover
  149. 403 running hot
  150. Retard or advance the factory W-30 camshaft
  151. Rearend traction bars for racing and adjustable control arms
  152. Pro comp 69cc head
  153. 1983 royale delta 88 63,000 miles
  154. 1971 442 correct headers ?
  155. Exhaust Cutouts and 1/8 Mile Fun
  156. Need Help Finding
  157. Oil pan's
  158. BOP race at Cordova Dragway
  159. 16+ Street Cars
  160. Sub 12 Street Cars
  161. Big Block Olds Blower Intake
  162. Pushrod recommendations
  163. Edelbrock “Small Block” heads
  164. OCA, Ozark 1/4 mile runs 2024.
  165. Intake manifold fit???
  166. Belt Drive from PDD
  167. Dyno results
  168. Estimate: 1994 Cutlass Supreme 1/4 Mile ET
  169. Customers 455 Olds Build
  170. Turbo 400 Sonnax smart drum
  171. Dyno Headers
  172. stroker crank for 350
  173. Engine mounts for higher horsepower cars
  174. Oil pump?
  175. Efi
  176. Supercharger 65’ 400
  177. Power numbers olds 350. Is there more in it?
  178. Tripower intake power vs 4barrel
  179. Clutch failure
  180. Another Max effort small block build
  181. Counterfeit Parts
  182. 403 vs 403
  183. Saw this on Instagram
  184. 4/7 swap cam.
  185. 455 Intake test, Performer vs RPM vs Victor
  186. 1967 Cutlass Supreme Ram Air
  187. Horsepower vs Torque Explained
  188. My out of the box Edelbrocks up & running
  189. Oil restrictors in a 455
  190. Speedmaster heads
  191. High performance builders near SC
  192. 1/4 mile E.T
  193. yet another header post
  194. The W43 at the Autorama
  195. comp cams roller rockers 17044-16
  196. Stock Appearing tire prep
  197. WTB 45* solid roller
  198. 1969 Cutlass Header Fitment Issues
  199. The PDD Billet Head getting closer to dyno time.
  200. What Torque? - McLeod and ARP
  201. PDD CCN manufacturing
  202. PDD CNC ported Edelbrock flow numbers
  203. Shorties vs Long tube headers
  204. Machine Shop Recommendation, Chicago
  205. How well do Headman Headers fit G Bodys?
  206. AN fuel line
  207. Solid body mounts
  208. Max lift from hydraulic roller
  209. Out of the box Edelbrock heads
  210. Flat tappet lobe profiles ?
  211. 434 ci DX build
  212. Let’s talk oil pans
  213. Solid roller lifter recommendations
  214. Canton oil pan, what should the dipstick read?
  215. Dynamic compression and online calculators explained
  216. High Performance Oil Pans
  217. Dyno session with Mark Remmel
  218. Experience with Holley Dominator SBO Manifold under Boost?
  219. Olds 455 Mild Build
  220. PDD Head
  221. 455 Build
  222. Compression static, dynamic and runner size
  223. New edlebrock Heads
  224. Builders and cores
  225. New Edelbrock 750 Carb
  226. Aluminum rods
  227. M/E Wagner High Performance Adjustable PCV Valve
  228. For those that used to frequent Realoldspower
  229. Cordova BOP race
  230. torker vs speedmaster intake
  231. Head Gasket recommendations
  232. Break in oil
  233. Stock Appearing
  234. High Volume Fuel Pump Options
  235. Mounting a cam degree wheel to the crank Olds 455
  236. Tri State Drag Live Steam on Now
  237. CNC Ported Edelbrock Heads
  238. Mocked up the twin TorqStorms
  239. BOP race at Byron
  240. Milled Cylinder Heads To Increase Compression
  241. Another New/Additional Product
  242. 1988 factory racecar.
  243. Class win for David Bares
  244. Mild low buck 350 build.
  245. Mild 350 build
  246. Still Chasing that 60
  247. 496 Build
  248. New 66 race car
  249. Oil pressure in fl heat
  250. Olds shaft rockers speedmaster
