High Volume Fuel Pump Options
Old Sep 13, 2023 | 06:15 PM
TheBigBlueBoat's Avatar
I'm trying to make sense of some of the high volume fuel pump options out there.
The "stock" options are generally labeled as 40GPH. I presumed most were labeled in terms of free flow- is that the case?
The other recommendation is the Airtex 40736, which looks like it's near impossible to find. (Maybe better luck searching for it as a later Toronado stock replacement?) The RobbMc site seems to suggest the 40736 pump is 80GPH free flow, ~40GPH @ 4.5psi. It also looks like it might be too tall to clear the SBO A/C brackets.
The Carter M4871 seems to have different ratings depending on where you look- a "minimum" 40GPH flow rate per the Carter website, and a "maximum" 120GPH on places like Jegs or Summit. Even if that was free flow, that seems like an astronomical flow rate. But is it even a "performance" fuel pump, or a stock replacement?
The other option is the Top Street Performance high volume pump and its clones, which depending on where you look is rated for 80GPH at either free flow or 6psi. If that's free flow, it's basically on par with the 40736, but in a fancy billet package that might fit better (and unfortunately be a little more conspicuous.)
Does anyone know which numbers are true?
Of course the RobbMc pump is an option but more performance than I would need, and wouldn't clear my A/C bracket.
Old Sep 13, 2023 | 06:52 PM
VC455's Avatar
Barely Registered
Call Robb and ask him about pumps. He'll answer your questions about flow and fit.
Everything I've bought from him is well engineered, durable, and nice looking.
Old Sep 15, 2023 | 06:28 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The Carter fuel pumps have been adequate for most engines on here. What HP are you running?
Old Sep 15, 2023 | 07:53 AM
Are they mostly a stock replacement or a performance one? I see a lot of them rated at 30GPH as well.
If I can make 450hp on motor I'll be pretty happy. Additional power from spray will be on a separate fuel system anyway.
Old Sep 15, 2023 | 03:07 PM
I have a friend with a 455 powered 66 cutlass using a Airtex 40736 pump. It runs 12.20s, with the Q-Jet.
I remember last year Joe, myself, and a couple others were discussing the fuel volume capabilities published. It appeared the pump arm
pivot was in the same location, so unless the internal valves are bigger the the only real difference is the canister size. Maybe that’s enough of a crutch for a less than ideal pump.
Old Sep 15, 2023 | 07:24 PM
Bernhard's Avatar
I ran a Carter on a mild 350 and it could not even supply enough fuel to support 5500 rpm shift point.
Old Sep 15, 2023 | 07:48 PM
Rallye469's Avatar
I’ve run a McRobb pump down to 10.96@121.
When I switched to an Aeromotive electric pump there was zero change.
Which meant it was probably good for more.
Old Sep 16, 2023 | 05:11 AM
https://www.summitracing.com/parts/crt-m4516
Apparently the M45XX series produces 10 more gallons per hour than the M60XX series. The 3 line is in stock, two line special order. The billet may put out enough, give it a shot if not expensive. Try either but you may need either an electric or modify to fit the RobMc pump at your power level.
Old Sep 16, 2023 | 10:22 AM
You mentioned above a SBO. Yeah, 450 out of one of those would make anyone happy.
Old Sep 17, 2023 | 06:27 AM
Just follow rouge_ryder's build and with slight tweaking, like the new Edelbrock heads in place of the Speedmaster heads and you should be right there. Good to see 400 HP is the old 300 HP in the Olds 350 world.
Old Sep 17, 2023 | 06:30 AM
Run to Rund's Avatar
I ran out of fuel by the 1/8 mile with the Holley chrome mechanical pump. The Holley red pump has been good for about 15 years now. I run a Jeg's metal screen cartridge filter in line, and the pump is next to the tank on a bracket bolted to the trunk floor.
Old Sep 18, 2023 | 06:33 PM
Bernhard's Avatar
Bernhard wrote:
The body broke on the Holley chrome pump we had, it never even made it two the track. In my opinion the factory original ACDelco pumps were better than the Holly chrome pump.
Old Sep 22, 2023 | 01:54 PM
CANADIANOLDS's Avatar
I’ve got a few customers still running very old Holley mechanical pumps. They’ve had to change out the main diaphragm because of the ethanol. But they work good for them.
at the track we’ve checked the pressure going through the traps and they are still putting out 5 psi. Fastest one is a low 12’s 455
they do tend to strip out the diaphragm bolt threads or crack the housing there if you have to remove the cover bolt more than once.
what I’ve done is epoxy a stud in the housing , then use washer and nut. That Top Street performance one looks like a remake of the Holley?
Old Sep 22, 2023 | 01:56 PM
Originally Posted by Bernhard
Where did it break?
Old Sep 22, 2023 | 05:56 PM
Bernhard's Avatar
Where did it break?
The mounting flange to main body casting. When we spoke with the speed shop owner he confirmed that others also had the same type of failure. The pump casting in my opinion was not as good as the AcDelco or Carter.
Old Sep 22, 2023 | 05:59 PM
Bernhard's Avatar
Bernhard wrote:
Was the low 12's 455 running a Qjet or other?
Old Sep 23, 2023 | 02:19 AM
Q jet
carnutz
Mar 31, 2024 10:49 AM
Sircajun
Sep 15, 2018 11:05 AM
69442
May 5, 2016 12:42 PM
HWYSTR455
Jun 27, 2013 04:48 AM
mhouston44
Jan 3, 2012 12:24 PM
