Ford Windsor roller rockers?
Would a pedestal mount Windsor setup work on a 350 head? Would that require guideplates? If so, do those require hardened pushrods?
I realize that careful attention must be paid to the sweep and finally assembly. I’m just trying to see what my options are with minimal machine work required.
You can run them, many have, myself included. There are 5/16" to 3/8" conversion studs for mild springs. I believe some are set for 5/16" bolts and some may not need guide plates. There are multiple styles, ratio and stud sizes for the Ford and Olds specific rocker arms.
Would a pedestal mount Windsor setup work on a 350 head? Would that require guide plates? If so, do those require hardened pushrods?
Wondered about pedestals but didn't borrow any to see how the fit up would have been
I have Ford Motorsport B351 1.7 rockers on my 403. Granted, not running but you still have to measure for pushrod length and shim them accordingly for proper preload like any other rocker. Yes, they fit under the factory valve covers. You'll use a stock length pushrod.
