Aftermarket timing cover
Old Oct 27, 2024 | 05:01 AM
dragline's Avatar
Is there a preference for an aftermarket timing cover? I see several outlets with the replacement steel cover. Any recommendations or who to avoid? I know if the oil seal hole isn't in the correct position you'll have oil leaks.
Old Oct 27, 2024 | 10:41 AM
BillK's Avatar
I am battling this right now with a customers engine. He bought a new cover and it is terrible. The hole for the seal is "funnel" shaped and it is off center from the crankshaft by about .030" I was actually planning to do a video of it on Monday. I ended up finding him a decent used one and glass beaded it and it looks great. His original was very corroded where the water pump goes on and coolant is hitting it.
I would almost say that if yours is in decent shape then just clean it up and re-use it.
Old Oct 27, 2024 | 04:26 PM
olds_freak's Avatar
I've had luck in the past with two different ones from Inline Tube. I have ran into those that have the crank seal hole that is tapered so the seal wont drive in no matter how hard you try.
Old Oct 29, 2024 | 09:48 AM
acavagnaro's Avatar
I bought one from Inline Tube a few years ago and it worked great. No problems.
Old Nov 7, 2024 | 05:36 AM
rickw30's Avatar
If anyone needs an OEM cover contact me.
Rick
OLDScience
Mar 28, 2024 04:34 AM
69oldsguy
Apr 23, 2023 03:12 PM
truckerlary
Apr 20, 2015 07:14 AM
jason
Mar 19, 2014 02:49 AM
rodbob
Mar 12, 2013 02:58 PM
