1988 toronado trofe fuel feed lines
You need nylon Dirman fuel line. It. comes in 3/8 and 5/16.
https://www.summitracing.com/parts/rnb-800-075
Most likely you'll need the 3/8 line with GM quick connect fittings to mate to your fuel filter and fuel rail. Also, make sure you have a heat gun to heat up the fittings before installing them in the fuel line. It's not an easy task.
