Rebuilt engine rapping noise solved.
Old Jan 13, 2026 | 04:18 PM
CANADIANOLDS's Avatar
This story is a good reminder that checking and re checking everything , even with new parts Is needed .
I got a call from a guy a few years ago who just had his 350 rebuilt and it was making a lot of noise. He sent me video of the engine running in neutral and running down the road. he thought it was spark knock, but nothing changed the noise when he fooled with timing or fuel. it made the noise mostly under light throttle and in neutral if brought the rpm’s up and let it float, it would rap like crazy
he sent me a video of it…I told him it sounds like a wrist pin, more than one. he pulled the engine and brought it back to the builder who tore it apart..he said the builder checked everything, bearings looked perfect, the bushing in the rod was perfect, no scuffing ok skirts and clearance was good.
Cam and top end was checked, all good. put it back together and it made the same noise. he put less 1000 miles on it and it kept getting worse. he gave up and parked it,, totally disgusted. fast forward to a couple days ago and he called me asking if I was interested in buying the whole engine or parts from it …he gave up.
it had a lot of good stuff in it, 330 crank, bushed 403 rods, Diamond forged +.040 pistons, nice pan, HV pump, good cam and lifters, 7a heads worked on and a performer RPM intake. I bought most of it. while looking at the rods, I slid a pin in and it felt good. then tried the pin in the Piston and it was sloppy…checked the others and all were super sloppy…he looks at me and says WTF ? that’s your problem…he’s like Jesus Christ. It’s been 7 years fighting this thing and over $11,000 down the drain.
when I got home I measured the pin and the piston pin bores. they had .980” pins in a .984” pin bore. Looks like Diamond supplied the wrong pins . Diamond like many others use a .984” Chrysler pin in their 350 Olds piston because they are more common and there’s more pin choices.
be
here’s the Piston specs from Diamond .
Old Jan 13, 2026 | 04:29 PM
Old Jan 13, 2026 | 04:52 PM
Funkwagon455's Avatar
Do you see evidence of any induced damage on the piston bores? What a sad story.. The kind of stuff that makes people go corporate or LS.
Old Jan 13, 2026 | 06:58 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Holy, that sucks.
Old Jan 14, 2026 | 05:31 AM
CustomBruiser's Avatar
That's crazy that the builder missed that when checking and assembling the pistons and rods.
Old Jan 14, 2026 | 09:24 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
The Mahle 350 pistons have that size as well, rods need a hone.
Old Jan 14, 2026 | 09:42 AM
the rods were bushed and ok. Active Engines in Mississauga built this thing, it sounded like it was full of marbles
Old Jan 14, 2026 | 09:44 AM
true..but a hack who just put some assembly lube on them without checking them dry first, would probably never have felt they were loose
Old Jan 14, 2026 | 09:47 AM
loose pins won’t hammer the walls..it’ll eventually pound the pin bores out of the piston.
Old Jan 14, 2026 | 09:50 AM
Holy, that sucks.
the 350 was in a 70 W31. he ended up selling all his Olds stuff and bought a 74 Mustang Grande🤢
Old Jan 14, 2026 | 09:54 AM
here’s how a correct .984” pin fits..perfect
Old Jan 14, 2026 | 11:48 AM
That's even harder to hear. Yeah, hard not be pissed. Something simple but a nightmare if they screw it up like this. A 1974 Mustang Grande, boy did he ever give up on life.
Old Jan 14, 2026 | 11:58 AM
68post's Avatar
That's crazy, and sad!
Did this egg the pin bore of the pistons, if so could they be honed to .990, correctly?
Old Jan 14, 2026 | 02:52 PM
I did a dial bore gauge measurement today..they’re fine. Still have the original honing cross hatch marks. being a good quality forging helps.
I doubt a cast piston would last very long. I was wrong on the mileage. I picked up the rest of the parts today and he told me he only drove it 360 miles total after the rebuild.
Old Jan 14, 2026 | 02:59 PM
I misunderstood you. The piston pin bores are ok
Old Jan 14, 2026 | 03:18 PM
VORTECPRO's Avatar
be
There's a reason why I don't use Diamond for anything, a lot of people love them, but not me.
Old Jan 14, 2026 | 03:47 PM
68post's Avatar
Where has the quality control gone?
Sad that yet another company previously thought of as "high quality" has gone low, this should've been an easy catch before shipping out.
Old Jan 14, 2026 | 05:16 PM
VORTECPRO's Avatar
They have always been sketchy...................this didn't just start lately.
Old Jan 14, 2026 | 05:37 PM
68post's Avatar
Thanks!
Old Jan 14, 2026 | 07:05 PM
All good. I appreciate your constructive feedback, perhaps I was not clear about my concerns. I truly hope that you all can come to a reasonable solution. Take care!
I certainly do hope that the op can come to an agreeable solution to provide some mutual benefit.😃
goatwgn
Jan 8, 2026 12:12 PM
goatwgn
Nov 25, 2025 02:14 AM
Bill X_R
Mar 17, 2023 07:06 PM
ragtop70
Sep 24, 2012 03:44 PM
sammieolds
Jun 22, 2011 09:57 AM
