Performance parts suggestions
Old Sep 2, 2025 | 03:50 PM
hook90's Avatar
Hey Guys,
As most of you know I have been offering a 4.00” Billet Stroker crank for both 350 gas blocks as well as DX’s for a few years now. Average selling price was approx $2100.00. They’ve done well but I’m always striving to make things better.
So now I’m working on being able to offer a FORGED 4.00” stroke gas block crank with all the same features as the original billets but for a more competitive sale price of around $1200.00. Any interest? I believe this revision makes more sense than the original billets. I’ll still offer the billets for the D/DX blocks as those blocks make better use the stronger crank. However gas blocks are less durable, so a more appropriated strength crank makes more sense in my opinion
Let me know your thoughts and level of interest if you would please.
Thanks.
im rebuilding a 73 455 im looking for a rotating assembly atm i have purchased a edelbrock top end kit with the air gap not building full on drag car but definitely not stock what would be some good suggestions im a younger person that dont know much all advice helps
Old Sep 3, 2025 | 07:53 AM
SteveDB's Avatar
Stuck in the 80's
Here is some suggestions.
https://classicoldsmobile.com/forums...rt-1-a-187621/
https://www.themotorbookstore.com/ol...SABEgJgbPD_BwE
Try to make a plan before you start buying parts, it will save money in the long term.
Cutlassefi on here is a great person to provide a cam that will suit your realistic needs. I have purchased multiple items from him and am 100% satisfied.
Most of all enjoy the journey... Cheers
Old Sep 3, 2025 | 08:12 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
X2 on talking with Mark, he will have some nice pistons and rods for the top end kit you got, what cam came with your kit if you dont mind sharing?
Old Sep 3, 2025 | 08:51 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
X3 on Mark. You need smaller dish pistons obviously. Better pistons and rods is a good idea but not cheap all by itself. You will also need a good machine shop familiar with Olds V8's. The BBO needs high quality machine work with proper clearances or expect a failed engine.
Old Sep 3, 2025 | 11:14 AM
hook90's Avatar
i have a edelbrock hydraulic flat tappet duration 290/300. lift is .496/.520 intake duration @050 inch 224/234. @skyhigh
Old Sep 8, 2025 | 12:40 PM
CustomBruiser's Avatar
Are you looking to replace the entire rotating assembly?
Old Sep 8, 2025 | 01:27 PM
Edelbrock should offer a roller cam package with the heads, intake and gaskets now that they are in the same group as Comp Cams. Cost can snow ball in a hurry but new pistons and machine work are necessary with the 77cc heads with a 224/234 cam with 8 to 1 compression. Also realize a higher stall torque converter will be needed.
fast73supreme
Nov 29, 2016 10:50 PM
Nunyadam Biz
Dec 5, 2012 04:38 AM
Chris Wicks
May 26, 2012 09:01 PM
Kidcutty
Feb 3, 2010 05:56 PM
Want-A-Vert
Mar 7, 2007 12:34 PM
