Aluminum Head Question
Considering a pair of aluminum heads for my 455. I'd like to know are they worth it? Which ones work the best? Where is the best place to buy? Or stick with stock heads grind the crap out of them?
Not true. The new Edelbrocks out of the box flow significantly more than any stock iron head.
Are they available straight from Summit now? Just through you Mark?
Any A&B tests done on a stock to mild build yet?
Glad there's something better out there.
Last back to back I did was on a mild 455 with big valve E’s. They made 37hp more than the irons.
Probably a lot of weight savings here too.
I'm guessing that a 455 with aluminum heads and intake wouldn't weigh much more than an all iron small block Chevy ( 540 LBS ).
Does anybody know what a 455 weighs with aluminum heads and intake?
That 58 pounds, especially on the front end, ought to make at least some difference in ET.
The 605 lb factory Olds 455 loses 92 lbs. 42 lbs saved from the intake swap and 50 lbs saved from swapping heads.
Thanks to Oldsragger and TripDeuces. https://classicoldsmobile.com/forums...weights-90666/
http://www.carnut.com/specs/engdim.html
513 lbs.
That 92 pounds should make some difference in ET's.
