Aluminum Head Question
Old Dec 3, 2024 | 10:04 AM
curban11's Avatar
Considering a pair of aluminum heads for my 455. I'd like to know are they worth it? Which ones work the best? Where is the best place to buy? Or stick with stock heads grind the crap out of them?
Old Dec 3, 2024 | 11:48 AM
cutlassefi's Avatar
What’s the application, stock, performance, race?
Old Dec 3, 2024 | 11:52 AM
curban11's Avatar
Performance with the odd run down the strip half dozen times a year
Old Dec 3, 2024 | 12:39 PM
Rallye469's Avatar
All depends.
Not sure any out of the box stock aluminum head will do much for you.
If you buy a set from a builder who will port them...then you'll notice some gains.
Old Dec 3, 2024 | 02:19 PM
cutlassefi's Avatar
All depends.
Not true. The new Edelbrocks out of the box flow significantly more than any stock iron head.
Old Dec 3, 2024 | 04:09 PM
curban11's Avatar
Oh? Do you have a model or part number?
Old Dec 3, 2024 | 04:51 PM
fleming442's Avatar
I refuse to buy Speedmaster Ding How knockoffs, especially after they copied that dude's logo on his billet valve bodies.
Edelbrock all the way, unless you can afford PDD or Kellen billets.
Old Dec 4, 2024 | 09:11 AM
Rallye469's Avatar
Apologies...I actually forgot about these new offerings.
Are they available straight from Summit now? Just through you Mark?
Any A&B tests done on a stock to mild build yet?
​​​​​​​Glad there's something better out there.
Old Dec 4, 2024 | 10:59 AM
cutlassefi's Avatar
They’ve always been available from the mail order houses. I never had an exclusive at any point. My focus has always been to make parts like these available to the masses.
Last back to back I did was on a mild 455 with big valve E’s. They made 37hp more than the irons.
Old Dec 4, 2024 | 05:47 PM
Charlie Jones's Avatar
Phantom Phixer
Probably a lot of weight savings here too.
I'm guessing that a 455 with aluminum heads and intake wouldn't weigh much more than an all iron small block Chevy ( 540 LBS ).
Does anybody know what a 455 weighs with aluminum heads and intake?
Old Dec 4, 2024 | 06:20 PM
VC455's Avatar
Barely Registered
Aluminum heads and intake save about 58 pounds off an iron engine weight of about 620 = 562 pounds. Maybe not perfect, but a good approximation.
Old Dec 4, 2024 | 06:35 PM
Phantom Phixer
OK, about 22 pounds more than an iron SBC.
That 58 pounds, especially on the front end, ought to make at least some difference in ET.
Old Dec 4, 2024 | 07:15 PM
69CSHC's Avatar
513 lbs.
The 605 lb factory Olds 455 loses 92 lbs. 42 lbs saved from the intake swap and 50 lbs saved from swapping heads.
Thanks to Oldsragger and TripDeuces. https://classicoldsmobile.com/forums...weights-90666/
http://www.carnut.com/specs/engdim.html
Old Dec 4, 2024 | 10:05 PM
Phantom Phixer
Originally Posted by 69CSHC
513 lbs.
Even better.
That 92 pounds should make some difference in ET's.
Bigmikey65
Feb 15, 2021 02:31 PM
djdrgn67
Jul 29, 2020 10:06 PM
mcalvo
Feb 14, 2016 05:43 PM
drjr56
Jan 9, 2014 01:46 PM
cutlassefi
Nov 12, 2013 09:51 AM
