434 ci DX build
Old Dec 8, 2023 | 07:19 AM
cutlassefi's Avatar
434 ci DX build
Here you go;
DX block
My DX 4.00” Stroker crank
Mahle 4.155 pistons, 10.5:1
Lunati 6.125 rods
Custom hyd roller
BAM .937 solid roller lifters
CNC’d Speedmasters (Early version)
Victor cleaned up by Wilson manifolds
My 1.7/1.65 HS rockers
Holley Terminator TBI
587hp/540tq
Old Dec 8, 2023 | 07:38 AM
SteveDB's Avatar
Stuck in the 80's
Mark,
Always great to see your builds and results. Appreciate you continuing to share.
Old Dec 8, 2023 | 11:55 AM
VC455's Avatar
Barely Registered
Mark,
Beyond the prodigious power...
That's a gorgeous build! Nice workmanship and attention to detail.
Cheers,
Gary
Old Dec 8, 2023 | 11:57 AM
therobski's Avatar
Sweet Mark, now let's wait and see where it will be planted!
Old Dec 8, 2023 | 12:23 PM
Rallye469's Avatar
Nice!
Have the sheet? I'd love to see the curve on this thing
Old Dec 8, 2023 | 01:10 PM
Bernhard's Avatar
Nice Build.
Old Dec 8, 2023 | 02:12 PM
cutlassefi's Avatar
Thanks guys!
’69 Cutlass with a 4 speed and 3.91 rear.
Old Dec 8, 2023 | 02:45 PM
oldsmoboogie's Avatar
Nice work!
Old Dec 8, 2023 | 02:47 PM
Man, the torque curve looks like Kansas. Awesome!
Old Dec 9, 2023 | 04:06 PM
JohnnyBs68S's Avatar
I'm just a drooling, here. Nice work.
Old Dec 9, 2023 | 08:52 PM
oldsfromyell's Avatar
That'll be an absolute blast in a clutch car. Great job Mark
Old Dec 11, 2023 | 05:25 AM
oddball's Avatar
Mark, as expected, the torque curve on my 440 looks almost the same from 3900 to 5000, but the mine starts falling off at 5,100 due to the Performer RPM.
What's the 0.050" numbers on those lobes?
How is the Terminator TBI working out? I just ran a 2 barrel Sniper 2 on a straight 6 in a '65 C10 and, once we got the original distributor to work correctly, ran really really well. Much better than the ongoing battle with a first gen MSD Atomic TBI on a mild SBC. Hilariously, that 2 barrel Sniper has a "cam" configuration screen with only one option: "Stock/mild". Very presumptuous of them, I think.
Old Dec 11, 2023 | 06:27 AM
KCTexan's Avatar
Going to "dog ear" this post for my '69 DX "some day" build!
Old Dec 11, 2023 | 08:21 AM
cutlassefi's Avatar
Originally Posted by oddball
What are the 0.050" numbers on those lobes?
With the big lifters it comes out to 246/254@.050.
Terminator is probably the best of the worst. As you know I don’t regard TBI units as “fuel injection”. But these work ok. You just need to really limit the learn almost immediately after getting a base map, and do the rest yourself. Otherwise, they don’t repeat very well pull to pull.
Old Dec 12, 2023 | 06:10 AM
oddball's Avatar
Ah, almost an extra 10 degrees on that cam. What's the intended use of the engine?
Old Dec 12, 2023 | 06:28 AM
deadeyejedi's Avatar
This is the motor I want 👍 and love that it’s spinning at 6000 rpm’s and making power . Nice work , maybe someday
Old Dec 12, 2023 | 06:43 AM
cutlassefi's Avatar
Fun😉
Old Dec 12, 2023 | 09:58 AM
fleming442's Avatar
But, it's all done at 6k, too
Old Dec 12, 2023 | 10:07 AM
True ! but still all I would need my ***** are a lot smaller than they used to be 😳
Old Dec 12, 2023 | 10:14 AM
Sugar Bear's Avatar
Mark,
WOW, very nice!
​​​​​​Please consider posting a video and audio clip of one of these builds. I'd like to play it very loudly in my daily driver...it would be kind of like "make believe" performance. 😬
Old Dec 12, 2023 | 11:20 AM
cutlassefi's Avatar
Mark,
WOW, very nice!
Lol!
Bruce, actually the Dyno sheet posted doesn’t really give the whole story. It was still making in the 580’s around 6200. (Never look at the first and last number as being correct). I’d say a redline of 6600 or so would prove to be optimum.
Old Dec 12, 2023 | 12:04 PM
chadman's Avatar
That's a nice build!
Old Dec 12, 2023 | 01:58 PM
cutlassefi's Avatar
Thanks Chad!!
Old Dec 27, 2023 | 03:28 AM
rkk69olds's Avatar
This beauty is mine!. Mark did my 455 build so I knew this one would be fun. Going in my 69 Cutlass Convertible with a TH400 from JW Performance and 3.91 12 bolt from Brian Trick.
Old Dec 27, 2023 | 04:57 PM
Fpcopo's Avatar
I wish I had known about those lifters when you helped me with my build Mark. Do they have those .937s available in hydraulic?
Old Dec 28, 2023 | 06:33 AM
oddball's Avatar
BAM only makes solid lifters. Sure, setting the lash on a hydraulic cam is a bit tricky (you want close to zero but not zero when cold), but at least for me it's not any noisier than it was with hydraulic lifters.
Old Dec 28, 2023 | 07:31 AM
cutlassefi's Avatar
Old Dec 28, 2023 | 07:49 AM
Fpcopo's Avatar
Thanks. I went to their website and it didn’t say anything about hydraulics.
oldsmoboogie
Feb 15, 2026 05:11 PM
cutlassefi
Oct 20, 2024 03:04 PM
cutlassefi
Nov 24, 2022 06:45 AM
cutlassefi
Apr 25, 2021 10:50 AM
Bernhard
Nov 22, 2012 07:12 PM
