Piston to valve clearance question Edelrock heads xe284 cam
Old Nov 11, 2024 | 02:38 AM
JLawrence's Avatar
Anyone here have Edelrock performer rpm heads on a 1970 STOCK bottom end 455 with a comp cams xe284 camshaft?
I'm curious before I take this thing apart if I will have piston to valve clearance. I have actually never measured this clearance on an olds also never put a cam like this in an olds or head aluminum heads on an Oldsmobile before
Old Nov 11, 2024 | 04:45 AM
fleming442's Avatar
It's very difficult to get piston to valve conflicts, if not impossible, in an Oldsmobile engine. Off the shelf parts lessen the minimal risk even more.
Old Nov 11, 2024 | 04:48 AM
cutlassefi's Avatar
You’ll have a mile and a half, you’re fine.
Old Nov 12, 2024 | 10:37 AM
JLawrence's Avatar
Thank you to both of you that answered. I just didn't want to take this thing apart and it not work out with the parts I have. I've had these problems in the past with some of the Ford stuff I've done or worked on.
Old Nov 12, 2024 | 12:03 PM
dc2x4drvr's Avatar
Stock compression?
Old Nov 13, 2024 | 04:58 PM
JLawrence's Avatar
Stock compression?
It's a 100% stock 1970 455
I'll clay the pistons but just wanted to know if it would most likely work before I took it apart
Old Nov 13, 2024 | 05:44 PM
dc2x4drvr's Avatar
That cam likes 10:1 compression, good valve springs, doesn’t like power brakes..
Old Nov 13, 2024 | 06:36 PM
ben442's Avatar
Agree that this cam likes compression, Power brakes work well for me.
www.youtube.com/shorts/vv5N9GxlmZk
Kapos79kutlass
Jun 5, 2023 04:13 PM
CajunCutlass
Nov 3, 2022 05:28 AM
67Olds442X2
Oct 20, 2019 10:15 AM
sicky olds
Jan 14, 2011 04:39 AM
Gearhead442
May 13, 2010 08:45 AM
