What heads to choose for 455?
Old May 11, 2010 | 06:51 PM
Gearhead442's Avatar
Olds + Mopar = Happiness
I am building a hot street car that i want to get at least 460 horse out of and i am just wondering what would be better bang for the buck here. I have been looking for a pair of edelbrock heads for the 455. I hear that they are the best flowing aluminum heads on the market, but 1700-1800 is very pricey. C heads are also worthy candidates for porting and valve jobs but prices add up. there are refinished ported C heads on the internet ranging from 500-1100 dollars, using the same size valves as the edelbrocks. are heavy port jobs on the c heads that cost anywhere from 900 to 1,000 bucks or higher better then the edelbrocks? as in flow (can not find flow charts of high end ported C heads). Or would it be better to just spend the extra money on the edelbrocks? Obviously the weight loss would be a great benefit thanks for the help.
Old May 11, 2010 | 07:43 PM
cutlassefi's Avatar
Don't need Edelbrocks to get 460 hp out of a 455. The right cam, compression and overall combination will get you there no problem. Use the C's, clean them up, a good 4-5 angle valve job, put in bigger valves and you're on your way.
Old May 12, 2010 | 07:01 AM
What type of heads do you have now?
Old May 12, 2010 | 03:15 PM
507OLDS's Avatar
Like EFI said,a simple valve job,a larger intake valve,& a correct cam will make that much & then some.
Old May 12, 2010 | 07:42 PM
442_Mustang's Avatar
An additional expense on those Edelbrocks are the rocker arms, pushrods, and bolts. I have them(Edelbrocks) on mine and my engine guy says they are a decent head as a starting point. He likes to enhance everything so he did a little porting and a valve job but you could just bolt em on, and get the correct rockers(Actually Ford 351 Winsor) and pushrods.
Old May 12, 2010 | 10:12 PM
geckonz08's Avatar
there is maybe only 10% diff between A to G heads . I have seen some flow comparisons somewhere. big valves n port n polish .
Old May 13, 2010 | 08:45 AM
Warhead's Avatar
If that, as long as the intake valve sizes are the same.
You can get J heads for free (seen a bunch being given away on ROP), and you will easily make your goal. Get any cylinder head that you obtain, rebuilt.
Do NOT run old used junk.
Jim
ldc7675
Aug 4, 2012 06:02 AM
bittersweet71
May 21, 2009 07:35 PM
Threejdsolds
Drivetrain/Differentials
Mar 14, 2009 10:54 PM
scubastever
Mar 5, 2009 04:56 AM
olds59
Feb 19, 2009 04:38 PM
