Engine mounts for higher horsepower cars
Old May 18, 2024 | 11:24 AM
oldsmoboogie's Avatar
Hello,
I have put the big block back in my 72 for the Sick Summer race in a few weeks. The engine is about 550ish horsepower and i may be using a small shot of nitrous. I put new mounts in the car about 12 years ago and were fine with the last motor. This has more movement when i accelerate. Besides a motor plate what is everyone using to help with the torque? I see there are some solid mounts on ebay. Should I put one on the driver side and leave the stock mount on the passenger side?
Old May 18, 2024 | 12:58 PM
Run to Rund's Avatar
I fabricated solid steel mounts for both sides of the engine, and used a stiff rubber (Moroso, probably not still available these days) trans mount.
Old May 18, 2024 | 01:47 PM
If it's not a dedicated race car, I prefer a solid mount on the drivers side only.
Old May 18, 2024 | 02:11 PM
young olds's Avatar
Maybe simply adding a strap is all you need?
Old May 18, 2024 | 04:23 PM
wr1970's Avatar
I use a solid mount. But I seen a turn buckle used also on driver's side. He used lock tight on the turn buckle because I asked him about it.
Old May 18, 2024 | 05:46 PM
Rallye469's Avatar
632HP 496.
Stock mounts with a chain on the drivers side.
It’s been that way since 2008. Don’t over think it.
Old May 18, 2024 | 06:49 PM
Bernhard's Avatar
Some street strip cars are running this mount. The person that makes them is on facebook.
Old May 19, 2024 | 05:27 PM
JohnnyBs68S's Avatar
Does anyone make a polyurethane or poylgraphite mount? Any advantage / disadvantage to running this? Asking for a friend .
Old May 19, 2024 | 11:54 PM
brownbomber77's Avatar
I drilled a hole in the motor mount and put a 5/16 bolt in it. I have far less than 500hp though....ha
Old May 20, 2024 | 03:29 AM
fleming442's Avatar
If these fit, that's the way to go.
No, that's why you have the home brewed ones above. Advantages: more power to the ground, will not rear the rubber and let the engine move. Disadvantage: more vibration through the car.
Of course, there's nothing wrong with a chain or turn buckle from the head to the frame, either.
Old May 20, 2024 | 05:23 AM
Thanks.
Old May 20, 2024 | 06:54 AM
67OAI's Avatar
Old(s)GuysRule
The mount shown in post 7 and post 10 has a polyurethane insert and is made by Michael Caplinger; contact info follows.
From Michael's post some time ago: "Im Michael, the one that makes those, Just logged back onto here. You can email me at
mikecap67@yahoo.com or text me at 858-752-9704"
Old May 20, 2024 | 05:21 PM
Thank you!
Old May 27, 2024 | 05:32 AM
rickw30's Avatar
I use the mount made by Mike.
Excellent quality and fit.
Does the job without using an ugly chain and turnbuckle.
Super nice guy !
Old Jun 7, 2024 | 05:32 AM
New2oldsw30's Avatar
I like that mount. Thanks for posting the contact info, will be ordering up a set from mike.
oldsmoboogie
Nov 26, 2019 02:47 PM
74 fastback
Oct 5, 2015 05:29 PM
1978 Oldsmobile Omega
Aug 11, 2014 06:35 PM
getawaycar
May 19, 2011 11:38 PM
panos
Feb 24, 2010 05:08 PM
