Stock Appearing tire prep
Old Feb 26, 2024 | 07:26 PM
Bernhard's Avatar
Old Feb 27, 2024 | 05:59 AM
herkguy's Avatar
Great vid, daily vs racing tire…what a difference.
Old Feb 27, 2024 | 06:57 AM
anoldsman's Avatar
Amazing setup!
Old Feb 27, 2024 | 08:03 AM
OLDSter Ralph's Avatar
While the "tire prep" can make a difference in traction, it takes more than tire prep to pop wheelies.
I do find it interesting that he does a couple short dry burnouts when competing and not spinning the tires in the "water box". The metal screws in the rim, low tire pressure, using inner tubes and short, dry burnouts is "old school" stuff that still works. Tire compounds have changed over the last 50 years too.
.....Just my two cents worth.
Old Feb 27, 2024 | 06:19 PM
Bernhard's Avatar
Notice the wheel screws were all on the inside of the rim. I'm sure they have removed all the stiction from the suspension and the spring rates and shocks are dialed in.
There is major money involved in that operation.
Old Feb 27, 2024 | 10:18 PM
Yes, but I thought I saw one tire in the video that had them on both sides. If the rules permitted, I would have them on the inside and the outside. I used a lot fewer screws.
Whats "stiction" ?
Yes, there is major money involved. But, you need "major power" to pop the front wheels.
Old Feb 28, 2024 | 02:47 AM
Rallye469's Avatar
Wish I had that kinda of time to JUST deal with tire set up.
Its obvious this is his full time hobby.
Still…fun to watch.
Old Feb 28, 2024 | 06:33 PM
Bernhard's Avatar
Whats "stiction" ?
Stiction is friction in motion, in this case I was referring to the control arms travel. Most likely these cars can be push with one hand in the lanes. I'm quite sure that the rim screws have to be kept on the inside of the rim to stay in the spirit of stock appearing. There is one build going together right now that is running large as in massive dome pistons, it will be interesting to see what that engine produces.
[QUOTE=OLDSter Ralph;1555751]Yes, but I thought I saw one tire in the video that had them on both sides.
You right watched the video again and the Vette has screws on both sides of the rim. I agree I would rather have screws on both sides and fewer of them, just like the way we used to run them. Why they were on only one side of the Camaro ?
Old Jun 7, 2024 | 05:44 AM
New2oldsw30's Avatar
Ya Pennyington's sure have the Vette stuff figured out. I'm actively looking for a '69 Vette to put my F.A.S.T. style ZL1 in and was thinking to send the chasses to them to do the suspension stuff. Not sure if Lane or Dave, being leaf spring guys, would help people out with there suspension stuff, or know where one with leafs could send there car to get the chassis sorted and baselined?
Old Jun 7, 2024 | 10:27 AM
Bernhard's Avatar
Have you joined the stock appearing Facebook group?
https://www.facebook.com/groups/765517070206972
Good luck with your new project the times that the cars are running on small tires are impressive.
Did you see the posts about the 69 Vette that went sideways in the top end and ended up in the barrier. The one positive is that car was well built with all the safety upgrades, so driver was able to walk away. He has already started a new build, you have to admire the perseverance in racers.
Old Jun 8, 2024 | 04:41 AM
Bernard, I don't do facebook, so no. My car won't "fit" there rules as I used headers and the intake is a '72. I believe the "parts" had tp be within 1 yr of the claimed yr your running.
Old Jun 10, 2024 | 05:21 AM
83hurstguy's Avatar
It's actually the opposite. Stiction = static (starting) friction. If the suspension is stuck in place and won't articulate, you don't have a chance in hell of getting it to articulate and work.
Old Jun 10, 2024 | 05:23 AM
83hurstguy's Avatar
I don't think you'll get much out of Lane or Dave unless you're sending a Mopar to Dave to get work done.
The ZL1 camaro had springs from Landrum in it, I think. Landrum has a lot of GM options, but weren't going to work for the Mopars we have. I have my own homebrew leaf spring setup made with extra parts from the local driveline shop and homemade clamps. I actually had a shock start leaking from the bending forces from spring wrap when I was using stock leaf springs to try a "softer" setup to absorb the hit.
Old Jun 10, 2024 | 08:12 AM
Bernhard's Avatar
Thanks for the correct explanation of the term.
Old Jun 10, 2024 | 04:41 PM
CANADIANOLDS's Avatar
I had to look up what stiction means…and I found out, nobody has a clue.
it sounds sexy…but in true technical and engineering terms, the word is hotly debated.
the best and most realistic use of the word means the breakaway force needed to overcome static at rest friction. it’s used most to describe the breakaway force needed to move the front forks on a motorcycle….when i googled stiction, that came up the most. the seals in the front forks of a motorcycle need to seal the fluid,, the friction from the seal on the shaft itself needs more force to move than they do to keep moving once the breakaway (stiction) force is overcome.
another thing that came up a lot was the force to break free a valve to get movement. they called it static or kinetic breakaway force..we’ve all experienced it…trying to break something free,?/‘s then, bang, the force drops dramatically once broken loose.
so I don’t know what stiction has to do with these types of cars? for one, all the automatic cars are brake torque’d to preload the suspension..you can’t shock these type of tires…they’ll go up in smoke. they need to have to TQ applied gradually…the stick cards are no different…no way is dumping the clutch gonna work…they are ridding the clutch the best they can to make sure the tires don’t break free..if they do, it’s over. that’s why the majority are automatic.
These types of tires need to lose rubber as they go down the track. the loss of rubber means they are bitting into the track , putting down rubber (losing it from the tire) while moving forward….there is no other way to move the car forward without losing rubber from the tire and putting it into the surface of the track…the narrower the tire, the more rubber loss there needs to be to move the car.
the suspension is critical..it needs to have the instant centre perfect which forces the rear axle into the track…that’s my theory. 😂😂😂
Old Jun 10, 2024 | 04:55 PM
Stiction is a new word which was invented in the 40’s by someone.
it’s not really an engineering term…you’ll find engineers arguing about what it is online. just ask,,you’ll get torn to shreds.
the word is a combination of STatic and frICTION ... it’s the difference between no movement and movement…I think?
I’m not an engineer..thank God for that
Old Jun 10, 2024 | 05:10 PM
You dont want the tire to breakaway…a perfect run down the track would have the tire roll the exact amount of its circumference to equal the length of the track..zero slip or spin.
that’s called perfect traction…but we all know that’s not gonna happen. in todays world we have driveshaft sensors and wheel sensors that tell us the amount the wheel/ driveline rotation relative to the track…we can reduce power from the engine to be just on the edge of breaking traction/contact with the surface of the track…
it’s the same with breaking ..to get maximum breaking traction to produce the minimum stopping distance…there needs to be no loss of traction ..no lock up..if the tire locks, or is just past the breakaway/traction point..it’s game over
Old Jun 10, 2024 | 07:54 PM
Bernhard's Avatar
Bernhard wrote:
One place the word is used is in the class racing world when describing the force required to move the control arms. You have the initial force to get the arms to move stiction. There is increased friction through out the control arms travel when using stock unmodified bushings. Some class cars are running Del-a-lum bushings. The old school method is to grind off the serrations on the upper control arm bushings. The control arms bushings are run with out side pre-load to allow the arm to move freely. The reason they do this is to allow the front end to move freely aiding in weight transfer and planting of the rear tires. Dale you already know this. The word might be new to the hobby, but the practice of lowering it goes back to the late 60's.
Old Jun 11, 2024 | 04:02 AM
Dp
Old Jun 11, 2024 | 04:11 AM
the del’s are still bushings with a lot of contact area. needle bearing inserts are way better. These lubed with oil, not grease. Stiction gone
Old Jun 11, 2024 | 06:54 AM
83hurstguy's Avatar
Static friction is pretty well defined. For the friction force calculation, there's a different coefficient that is used to define the friction force between two surfaces not moving, compared to dynamic friction which occurs once the objects are sliding. We dealt with stiction a lot more on cars that handle compared to drag racing, because every time you go through a suspension transient, it's present at the start, which can upset the car's balance.
Just because the car is preloaded on the converter, stiction is still there because the suspension isn't moving, and sometimes the force applied through the rear links could make it worse (like pushing down on a sanding block before it's moving). What matters is the motion as soon as you release the brakes and want the suspension to start planting. If the rear doesn't want to separate or the front to come up, you get no benefit from the transfer, unless you're lucky enough to have more than enough tire for the power level or great track prep.
Old Jun 11, 2024 | 06:15 PM
Bernhard's Avatar
Nice!
Do they fit GM A body control arms? I know that you have to run the pre 69 lower if you run the Del-a-lum as well as other lower friction bushings.
Old Jun 11, 2024 | 06:21 PM
Bernhard's Avatar
Luke thanks for the engineering term lesson and there proper application.
How did you have your 68 Hurst set up to run on the stock tire?
Old Jun 11, 2024 | 10:41 PM
the TQ converter being loaded isn’t the same as the rear suspension being preloaded. These cars don’t leave off a trans brake . The automatic cars leave off a stutter box and a foot brake or a combination of that and timing retard that is gradually put back in as the car accelerates.
the tires can’t be hit without suspension preload or they’ll break the tires loose. one of the fastest cars has no rear body separation at all..infact, it actually squats a bit in the rear ..the front does rise and transfer to the rear.
here’s three pics and a vid of the Camaro leaving. Pre stage no suspension preload, staged with rear suspension preloaded you can see the suspension get pre loaded and the rpm’s change with slight body separation , and third the leave. watch the vid from about 19.00 min point , there’s a secondary vid of the leave.
the rear is already at max travel and does not separate any further as it leaves..watch top of wheel well.
Old Jun 12, 2024 | 05:05 AM
83hurstguy's Avatar
Front end loose, rear end has TA performance no hop bars. I haven't raced it in two years, it wasn't even out last year or this year yet for a street drive due to not having time to fix a sizeable oil leak. It would do okay on a prepped track, but suffered on minimal prep - timing curve in the distributor was too aggressive. The no hop bars were a huge improvement. I had a new distributor curve I was starting to mess with on the Sun machine last time out but I can't remember the exact details. I've been racing / developing my 4 speed 'cuda... driving stick is so much more fun.
Old Jun 12, 2024 | 05:13 AM
83hurstguy's Avatar
How so? Loading the TQ converter in a footbrake car means the engine torque is being resisted at the brakes, and any antisquat / link load generated from torque will be transmitted through the suspension. If they left on a transbrake, I would agree you have 0% suspension preload. Agree on the digital timing control that has now become obvious with the 2 step at the line...
Agree on how the Camaro leaves (back end flat) and they have that car sorted out. I can't find the video now, but there was a video of the black 'cuda on the hub dyno with rear antisquat lifting the rear significantly with torque. I broke my car a few races ago so I got a lot of time to watch, and it's interesting to watch the differences... some cars squat a little, some leave flat, some separate the rear.
Old Jun 12, 2024 | 10:00 AM
what I’m saying about loading the TQ converter in a trans brake is nothing like a loaded suspension on a foot brake car..even though the converter is loaded in both apps.
there is also a vid of this Camaro on a hub dyno which shows huge rear suspension separation..it’s nothing like that at the track though. all a hub dyno is good for is engine data. a rolling chassis dyno would show some similarities as the track would but still not real life.
that Camaro usually runs mid 1.5 60’s but has dipped into a high 1.4 in perfect track and weather.
do you have any vids of your car and how it leaves?
Old Jun 12, 2024 | 02:28 PM
Camaro vid. The second vid starts about 19.15 min in. there is also a vid of it on the hub dyno
Old Jun 12, 2024 | 02:33 PM
The Camaro runs aftermarket aluminum heads..🙄
because..as everyone knows, Chevys have a tough time competing with other makes because those old aluminum heads are blah blah blah😁
Old Jun 12, 2024 | 06:57 PM
Bernhard's Avatar
https://www.youtube.com/watch?v=XeplWZJdu08
It's a good video, I was surprised he shares quite a bit of information as to how they run there car. The traction control is a big reason that they can drive away from the line with those factory tires.
Thanks for posting.
Old Jun 12, 2024 | 07:02 PM
  #31
Bernhard's Avatar
Those Chevy guys are hard done by, that's why the class racing lanes are filled with Chevy's.
Old Jun 12, 2024 | 07:49 PM
  #32
83hurstguy's Avatar
I have to dig on the Olds, probably on the wife's phone. I got a GoPro last year and started making videos of the 'cuda rear leaf springs, at first it was shocking how much the spring was twisting up, the next race was on crap track conditions and the leaf spring mods were making it more stable but still spinning. Leaf springs + 4 speed + polyglas is a real beotch. I'll try to find something this weekend and upload to youtube for everyone's entertainment.
Old Jun 14, 2024 | 08:54 PM
  #33
Bernhard's Avatar
I have seen some very fast GM A body and G body stock & supper stock class cars with next to no Squat or body separation. They are running stiff rear springs and controlling them with some very expensive shocks. I will see if I can find some video. I think the modern anti roll bar was a game changer and has helped a lot of cars. I don't know if it is legal in stock appearing but the Fast Car was sporting one. The cleanest install I have seen of an anti roll bar was on a local Chevelle,he placed the links through the center of the springs. I don't know if it is an ideal mounting point but it was very hard to spot. The bar was mount in the truck so unless the trunk was open most would never know.
Old Jun 14, 2024 | 09:02 PM
  #34
Bernhard's Avatar
Here is a 68 Hurst Oldsmobile from 2013 no squat or body separation
https://www.bing.com/videos/rivervie...4&&FORM=VRDGAR
Old Jun 15, 2024 | 08:33 AM
  #35
That car is from Minnesota. He won his class last year at Brainerd track. His brother runs a '53 ****** Americar with a 500 inch Oldsmobile and he is a member on here.
Here is a pic from last year of the H/O and owner with trophy.
Old Jun 15, 2024 | 01:13 PM
  #36
Bernhard's Avatar
I'm familiar with the car it's running Weibe suspension , Jason Line power and they are well under the index. Not an easy car to get under the index, definitely a fan of this stocker.
Vintage Chief
Apr 10, 2023 10:27 AM
teamwieland
Wheels and Tires
17
Feb 24, 2022 11:59 AM
droptopron
Feb 20, 2019 10:08 AM
Bfg
Jun 1, 2018 04:50 AM
Evans1
Feb 9, 2013 12:07 PM
