New Edelbrock 750 Carb
Old Oct 13, 2023 | 10:51 AM
cutlassefi's Avatar
Can’t wait to try it!!
Old Oct 13, 2023 | 11:49 AM
brotherGood's Avatar
I can't wait to hear your results. I've never been an Edelbrock fan-always a Holley fan. This just seems awful intriguing.
Old Oct 13, 2023 | 02:54 PM
cutlassefi's Avatar
Hope to have some numbers tomorrow.
Old Oct 13, 2023 | 03:17 PM
Are you going to compare it to another carb?
Old Oct 13, 2023 | 03:18 PM
SteveDB's Avatar
Stuck in the 80's
Saw a write up on these sometime back. They sure incorporated a lot of interesting ideas.
It will be great to see what you think.....
Old Oct 13, 2023 | 03:34 PM
Pretty cool! 😎
Old Oct 13, 2023 | 03:35 PM
With no choke how well would that work on a daily driver?
Old Oct 13, 2023 | 04:08 PM
cutlassefi's Avatar
Yes I’ve done over a dozen pulls on the build shown, a 403 with a 750 Brawler. I’m having issues with the Brawler carbs lately, even the better ones. So I thought I’d grab one of these.
And I’ll be doing more testing on my Edelbrock headed mule anyway so I thought why not.
But the 850’s and 950’s won’t be out till early next year so to do one of these on a big block will have to wait.
Old Oct 13, 2023 | 04:17 PM
cutlassefi's Avatar
Once it’s warmed up I would think it’ll work just fine.
There are 4 air bleeds per throat. So these should yield an incredibly flat fuel curve. We’ll see.
Old Oct 13, 2023 | 09:51 PM
I once had a Holley 0-1850 600 cfm that someone milled the choke air valve stuff off. The engine fired right up even on cold days, but wouldn’t drive until it ran a few minutes and warmed up. I guess it was rich enough at idle that it didn’t need the choke air valve.
Old Oct 14, 2023 | 12:11 PM
cutlassefi's Avatar
Here you go gentlemen.
Both were done at the same temp and timing.
Brawler has over 20 pulls on it, this was the best one. Edelbrock has just two, with just 1 power valve and jet change. There’s a bit more in it I’m sure.
I’ll take the 20 extra lb-ft of tq any day.
Old Oct 14, 2023 | 12:13 PM
Any reason the oil psi is different? Not that I'd equate carb change to oil psi, but still.
Old Oct 14, 2023 | 12:34 PM
cutlassefi's Avatar
Brawler pulls still had the Driven BR-40 in it. I changed it to 20W-50 VR-1 afterwards.
Old Oct 14, 2023 | 02:12 PM
Impressive, can you show the wide band readings between the 2?
Old Oct 14, 2023 | 02:48 PM
cutlassefi's Avatar
Yes, good question, that was next😉. I have 2 wide bands but the left one isn’t calibrated correctly. However you’ll see that, apples to apples, they’re very close between the 2 carbs.
Old Oct 15, 2023 | 05:20 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
What are specs on this 403? Nice numbers.
Old Oct 15, 2023 | 07:02 AM
cutlassefi's Avatar
I’m going to post on FB as well but;
4.390 Racetec piston, 9.8:1 comp
Molnar 6.125 rod
330 crank
My halo
222/228@.050 hyd roller, .555/.560 lift
RPM intake, port matched
New Edelbrock heads, just trued the surface
Taylor HEI
This build was done 5 times before, by two different other guys. It failed quickly every time for various reasons. I have almost 25 pulls on it, I really flogged it. Runs great.
Old Oct 15, 2023 | 07:28 AM
cutlassefi's Avatar
And a correction. The numbers posted for the “Brawler” are actually for my QF Dyno carb. Here’s a pic of it.
The Brawler took a tremendous amount of time to get right, and was about 3-5 numbers below the QF.
Old Oct 18, 2023 | 02:04 PM
cutlassefi's Avatar
As you can see, air/fuel didn’t vary more than a couple of tenths throughout both pulls, QF vs Edelbrock.
Old Oct 18, 2023 | 04:18 PM
CANADIANOLDS's Avatar
can you explain the left bank 14.69 max lean and being lean throughout the pull ?
Old Oct 18, 2023 | 05:16 PM
cutlassefi's Avatar
Yes, bad sensor. That’s why I drew an arrow on both the right side O2’s. Apples to apples.
Byron
May 15, 2023 01:22 PM
Andy
Oct 29, 2022 06:01 PM
cutlassefi
Sep 14, 2015 08:23 AM
Magna86
Oct 6, 2014 04:38 AM
tim72
Aug 4, 2009 08:30 AM
