Max lift from hydraulic roller
Running very large lift numbers with a hydraulic roller requires slot of attention to the rest of the valve train. It's better to run a solid as it allows springs that can control the valve action better.
Biggest HR lobe I’ve seen is from Bullet Cams. .450” is .720” with Olds 1.6 rockers.
there are off the shelf HR’s for bb Chev’s with .680” lift….That’s with awful valve train angles and a heavier valve train than the Olds.
