Max lift from hydraulic roller
Old Dec 23, 2023 | 12:11 PM
DROLDS707172's Avatar
What is the max lobe or valve lift that can be achieved with a hydraulic roller camshaft and lifter combination?
Old Dec 23, 2023 | 12:36 PM
cutlassefi's Avatar
I have .650 in the latest one I did.
Old Dec 23, 2023 | 02:41 PM
Hydraulic roller
Is it based off of RPM? Just wondering if I could go greater than .650?
Old Dec 23, 2023 | 04:16 PM
cutlassefi's Avatar
Get the head flow numbers first before you push it open that far.
Old Dec 24, 2023 | 04:01 AM
Duh's Avatar
Duh
TO actually answer your question. The max lift of a lobe has more to do with the minimum bace circle size. When a cam is ground the more lift needed the smaller the base circle becomes. So depending on the core used you can only go so small. The most common cast cam cores used with hydraulic rollers today only allow about .650 lift at 1.6:1 ratio. The best way with current cores is to increases your rocker ratio. Minimum bace circle has a lot to do with lobe design and you should talk to a grinder.
Running very large lift numbers with a hydraulic roller requires slot of attention to the rest of the valve train. It's better to run a solid as it allows springs that can control the valve action better.
Old Dec 24, 2023 | 07:53 AM
CANADIANOLDS's Avatar
Biggest HR lobe I’ve seen is from Bullet Cams. .450” is .720” with Olds 1.6 rockers.
there are off the shelf HR’s for bb Chev’s with .680” lift….That’s with awful valve train angles and a heavier valve train than the Olds.
Old Dec 24, 2023 | 01:19 PM
Get the head flow numbers first before you push it open that far. Peyton Hunt will be supplying those real soon
MartinH
Jul 1, 2022 04:30 AM
Gene kerr
Apr 21, 2022 08:56 AM
cdrod
Jun 9, 2021 03:07 PM
morrowjm4154
May 20, 2009 02:46 PM
Redog
Aug 14, 2008 06:56 PM
