Stock intake capability
Old Sep 10, 2025 | 09:04 AM
BBLima's Avatar
Do you think this cam would work with a 1972 olds 455 stock intake big valve heads 2.07/1.68 ported bowls and filled and shaped midlle exhaust ports. With W&Z manifolds 2.5 exhaust back. Engine 10.1 roller adj rockers, 750 quadrajet im thinking 109 ls duration @ .050 235/243 lift 501/480 wirh a 2600 convertor. nice rough idle with increased mid. Hp&trq. Thinking he bbo has has plenty of low end power and not looking to twist it over 5600-5800ish. I want to keep the stock intake to work with the factory oai hood set up and for original. PB,A/C car
Old Sep 10, 2025 | 09:12 AM
heatmup's Avatar
The W30 cam is 244/244 and the W31 is 232/232 duration, so it should be fine. There is improvement using an old Edelbrock 04B, and it will fit under the OAI.
Old Sep 10, 2025 | 09:27 AM
VORTECPRO's Avatar
If your cam has a 109 degree lobe separation, I don't think it will work well with the rest of your combination.
Old Sep 10, 2025 | 10:18 AM
BBLima's Avatar
Ok so what would you suggest for a cam that has a rough idle, and keeping power in the middle recline at 5600-5800 max with the combination listed
my second choice was a 520/542 lift 234/244@.050 w 112ls
Old Sep 10, 2025 | 02:20 PM
cutlassefi's Avatar
Originally Posted by BBLima
why do you say that?
Cuz the tighter lobe sep will cause a vacuum loss at and near idle. It may not play well with your Qjet either, unless the spring etc has been changed.
Being a big block I’d do it on a 111 or 112.
Just saying.
Old Sep 10, 2025 | 02:26 PM
BBLima's Avatar
Just saying.
I have done 108 ls with pb, with olds no issues but that was with demon carb,torker and edl. Heads.
if I got to modified the rochester not to concern. 108-110 sweet spot for the BBOlds. My problem I never did it with a stock intake,carb,manifolds
Old Sep 10, 2025 | 04:16 PM
VORTECPRO's Avatar
!09 won't work well with a restricted exhaust system.
Old Sep 10, 2025 | 04:31 PM
cutlassefi's Avatar
^^^^^ correct.
Old Sep 10, 2025 | 05:02 PM
Run to Rund's Avatar
I had similar ideas when I got Comp to grind me a cam with about 230I-236E at .050, mid 500s lift, 112 lobe separation for use with stock branched manifolds--or headers later if desired.
Old Sep 10, 2025 | 05:17 PM
BBLima's Avatar
^^^^^ correct.
Unless you have data to prove your statement, I dont buy it. In 68 H/O 455 produced 390hp/500trq with 308/474 cam and the exhaust x&y manifolds with 2.25 restricted mufflers and 2 tails.with W&Z manifolds and 2.5 exhaust to tails mufflers flow 486 each should be enough for 450hp also The w30 cam had a ls 108. With the stock restricted exhaust.
Old Sep 10, 2025 | 08:21 PM
VORTECPRO's Avatar
A W-30 cam had 108 degree lobe separation? I would disagree.
Old Sep 11, 2025 | 04:02 AM
BBLima's Avatar
the cam # 402569 used in 1969-1970 w30 manual trans had 108 do the research. No power brakes didn't make much vacuum but it used the restricted exhaust and made great #. Will I get more out of headers yes, but by bumping the duration on tthe exhaust it should help the restricted manifolds.
Old Sep 11, 2025 | 04:12 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Well you did ask for opinions on the cam, I would listen to the free advice you seek, they no cams very well.
Old Sep 11, 2025 | 04:15 AM
BBLima's Avatar
I have done a few been building all my life. My question is more on the intake working with the cam. I value peoples opinions with some facts or data to back it up versus saying nope.
Old Sep 11, 2025 | 04:35 AM
VORTECPRO's Avatar
56
the cam # 4029 used in 1969-1970 w30 manual trans had 108 do the research. No power brakes didn't make much vacuum but it used the restricted exhaust and made great #. Will I get more out of headers yes, but by bumping the duration on tthe exhaust it should help the restricted manifolds.
The cam I always used was the SpeedPro 176R which was a copy of a W-30 cam, which didn't have a 108 degree lobe separation. Curious as what kind of drag strip performance you expect from your build?
Old Sep 11, 2025 | 04:39 AM
BBLima's Avatar
56
Hey VORTECPRO here is another company that has the w30 not sure who is the manufacturer of it. https://www.oldsparts.com/product/68-9-w-30-all-70w-30-mt-cam-with-lifters/ my bad, 108 overlap not separation so the cam is a 110ls.
Old Sep 11, 2025 | 07:05 AM
OLDSter Ralph's Avatar
56
Hey VORTECPRO here is another company that has the w30 not sure who is the manufacturer of it. https://www.oldsparts.com/product/68...-with-lifters/ my bad, 108 overlap not separation so the cam is a 110ls.
For your information, there has been several "W-30" cams over the years. The 1966-67 W-30 cam was 308 degrees and was also used in the (Non A/C) W-45 1968 H/O. The A/C cars (W-46) used a much milder cam (285 or so degrees).
The 402569 cam was in fact 328/328 degrees and used in the 1968-70 W-30 engines.
You apparently confused Valve overlap duration with Lobe Separation Angle. Cutlassefi and Vortec were both correct.
Old Sep 11, 2025 | 07:15 AM
BBLima's Avatar
yes sir and I stated that, and I apologize for that.
being correct? About 109 to much for exhaust manifolds? If you look at the responses, they just say nope, with data or a cam recommendation. Of coarse im going to question it. Im open to recommendations but it be nice to see proof why it would not work
Old Sep 11, 2025 | 07:31 AM
I don't think anyone would waste time putting something together that will likely perform poorly to prove it. We can all sit back and let you build something that performs less than expected. You can prove to us what you got.
Old Sep 11, 2025 | 07:36 AM
BBLima's Avatar
Nope not trying to prove nothing and but just to understand. Im going with a different cam . And may even go with direct fit headers if need to be.
Old Sep 11, 2025 | 07:46 AM
What are "direct fit headers" ? Thats a term I haven't heard before.
Old Sep 11, 2025 | 07:53 AM
BBLima's Avatar
well it may not be the term, but they say they fit without and mods to the pipes, alt,ps and a/c brackets . They all fit as the stock manifolds. Oldsparts.com sell them. Pop out the manifolds and Install them. It gives me an option if the manifolds are a problem .
Old Sep 11, 2025 | 07:58 AM
Good luck.
Old Sep 11, 2025 | 08:01 AM
BBLima's Avatar
Good luck.
I need it. This sh.. trying to keep stock parts and original exterior appearance and make hp is a pia!
Old Sep 11, 2025 | 09:34 AM
acavagnaro's Avatar
Sounds like you're talking about short tubes. Like the kind Thornton sells.
Old Sep 11, 2025 | 09:53 AM
BBLima's Avatar
yes they sell them too
Old Sep 11, 2025 | 10:08 AM
VORTECPRO's Avatar
Here are the specs of what I believed was a W-30 copy cam that I've used several times in the past.
.474 EX
.474 Int
232 @ .050 EX
232 @ .050 Int
113 Lobe separation
Old Sep 11, 2025 | 12:23 PM
BBLima's Avatar
.474 EX
.474 Int
232 @ .050 EX
232 @ .050 Int
113 Lobe separation
Thanks for that info VORTECPRO.
Old Sep 13, 2025 | 02:32 PM
CANADIANOLDS's Avatar
Just saying.
not always…you know this. big advertised duration is what kills idle vacuum, not necessarily big .050 duration or tight LSA
I can run 235 to 240 at .050” int on a 108 LSA in a 10:1 455 and still have plenty vac to run pwr brakes with a factory dual plane and auto car in drive. these combos usually make 11 to 12” in drive at idle
the idle is nasty and comes on the cam by 2200 . 3:23 gear and a mild converter work great.
Old Sep 13, 2025 | 04:10 PM
cutlassefi's Avatar
Wrong again. The stock, factory W30 cam was ground on a 113lsa, not a 108 or even a 110.
Can you buy an aftermarket copy that’s ground on a different LSA? Of course you can. But they also use different, more modern Lobe profiles, which lessens the overlap as well.
And no one said it wouldn’t run, it would just run better with a wider LSA.
You've been misinformed to say the least.
Old Sep 13, 2025 | 04:19 PM
  #31
cutlassefi's Avatar
not always…you know this. big advertised duration is what kills idle vacuum.
Yep. But years ago advertised duration was done at .000 lift, not .008, like Engle, .006 like most of the rest, or even .004 like the old Crane and Erson stuff.
It’s pretty difficult to have an apples to apples comparison of the cams of yesteryear versus the cams of today on advertised duration.
Old Sep 13, 2025 | 04:38 PM
  #32
Andy's Avatar
BBLima,you got 3 guys on here that build engines for a living with proven results. You may want to heed the advice. Ultimately you will do what you want.. your choice.
Old Sep 14, 2025 | 08:37 AM
  #33
BBLima's Avatar
108 lobe angle on the lift and duration comes out at a 110 lobe separation not talking about the 113 lb for auto
Old Sep 14, 2025 | 08:40 AM
  #34
BBLima's Avatar
I have been building race engines for the past 30 yrs. Just never did anything with stock components and it looks like they didn't either.
Old Sep 14, 2025 | 08:44 AM
  #35
BBLima's Avatar
Its funny to see all the cam specialist out here. But I have to ask, whats the fastest qrt car you have stock head ,1 carb no turbo,supercharger or Nitrous on a 68-72 Cutlass.
Old Sep 14, 2025 | 08:49 AM
  #36
VORTECPRO's Avatar
Are you asking what's the fastest production Olds headed NA full weight car, any of these guys have run? Curious what you got along these lines, if you can, post up, I like to know what's out there myself.
Old Sep 14, 2025 | 10:26 AM
  #37
VORTECPRO's Avatar
You got me excited for nothing...................................
Old Sep 14, 2025 | 12:37 PM
  #38
BBLima's Avatar
I heard you got some good times on the qrt. But are they good enough to be the fastest ?Doesn't necessarily have to be a street legal just a cutlass body and at least part stock frame. Olds engine olds iron heads natural aspirated 1 carb no nos. Had or currently have. It's funny how no one is commenting anymore.lol maybe this is the wrong forum to ask for experience on stock parts makimg hp.
Old Sep 14, 2025 | 12:39 PM
  #39
BBLima's Avatar
I would say, it be a hard contender to beat.
Old Sep 14, 2025 | 04:14 PM
  #40
Bernhard's Avatar
https://www.facebook.com/reel/1258325382001213
NHRA legal stocker
