Sanderson center dump
Old Jun 25, 2025 | 06:20 AM
66gutlass's Avatar
Hey all! looking for a set of of either stock manifolds or some nature of header for my 350, not many cheap options up here in alberta. Local guy said he has some sanderson headers, center dump. Looked em up and pretty clear there is just about no way these clear the cross member, let alone the engine mount. chassis is a 1966 for reference.
So to the olds gurus, can these be made to work, or are these plain and simple a no go?
If these dont clear engine mounts and cross members, how exactly do these work on an olds???
Side note. looking at some cheap *** flow techs. Worth the trouble? had a set on my 94 pickup without too much trouble and need some nature of exhaust asap.
Old Jun 25, 2025 | 01:02 PM
JohnnyBs68S's Avatar
Sounds like the center-dump manifolds were designed for engine swap applications (into a T-bucket street rod for example). You'll need the rear dump factory type manifolds to avoid cross member interference in an A- or B-body chassis. Have you looked at shorties?
Old Jun 25, 2025 | 07:12 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
They won't clear. I had a set on my 94 Z71 with an Olds 350. Even with the the front 403 Trans Am motor mounts, it was too tight to route exhaust properly around the front differential. They won't work with center motor mounts for sure.
Old Jun 26, 2025 | 05:19 PM
68post's Avatar
Yes, cheap Flowtechs are worth it!
dragline
Oct 4, 2020 03:32 AM
Skribble93
Apr 8, 2020 08:36 AM
blee49
Nov 8, 2015 09:00 PM
odddoylerules
Mar 9, 2015 11:43 AM
defiant1
Mar 7, 2011 09:21 AM
