Camshaft RPM range
Old Jan 18, 2025 | 10:20 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Camshaft RPM range
I currently just have my rev limiter set at 4000 rpm, probably a few lower than peak with the 204/214 Edelbrock Performer plus camshaft. Curious where you guys would set the rev limiter with a hydraulic roller 218/218 .541/.541 with 1.65 ratio rocker arms with a 112 LSA? I was thinking 5000 rpm. Thoughts?
Old Jan 18, 2025 | 10:56 AM
SBO 350? You'll want to go higher than that. I'd think it would make power to 5200 or so with those numbers, so maybe 5500?
Old Jan 18, 2025 | 12:17 PM
Yes, should be just under 9.5 to 1 Olds 358 with the new 68cc Edelbrock heads. Easy to change the rev limiter, SEFI with the Holley Terminator X Max. I was kind of thinking 5500 rpm Max but low 5000's being more realistic being a mild cam.
Old Jan 18, 2025 | 12:27 PM
bccan's Avatar
I’m thinking 5500.
Old Jan 18, 2025 | 12:52 PM
cutlassefi's Avatar
Just look at your VE table. You’ll see it drop off more quickly once you’re past the hp peak.
Old Jan 18, 2025 | 12:56 PM
Good thinking, will do.
tru-blue 442
Nov 29, 2021 06:01 AM
Gone Johnson
Feb 12, 2018 07:39 PM
69CutlassAlex
Jul 30, 2013 08:18 AM
e129745
Nov 23, 2012 04:31 AM
mp71conv
Nov 18, 2008 03:57 AM
