Edelbrock Torker vs. Edelbrock Performer
I have a 455 with .472 Edelbrock Cam and lifters, 750 cfm Edelbrock carb, headers and a few other small upgrades and soon a set of C heads with a lot of performance mods. Which intake would be a better choice. I already have the Performer. Any experiences?
I am looking to put in a bigger cam. Looking at either .49 or .51 lift. The Edelbrock performer RPM range is Idle-5500. Any cam that is bigger than the .472 which I already have has an RPM Start Range of 1500 or higher. I would assume that putting a bigger cam with a higher RPM range with my current Edelbrock performer would be a bad idea? Thanks all
Even if I put a bigger cam in? My main concern is the initial overlap. Having a idle-5500 intake and a 1500-6500 cam. Is that slight offset bad? Don't you typically want a match RPM Operating range?
It's a package, here is a good article but read the whole thing:
http://www.enginelabs.com/engine-tec...or-dual-plane/
For what you are doing there will not be an appreciable difference. If you were looking for better times at the drag strip I would go with the Torker but for a mild street car you won't notice a "seat of the pants" difference. You said you are looking to change cams but only listed possible lift numbers. It's more the duration @ .050 and the LSA that determine the "attitude" so to speak of the cam much more so than the lift.
I also read that the camshaft and the Intake don't have to be exactly matched when it comes to RPM operation range but its good to have it within 500-1000 RPMs.
rhurstolds74
January 20th, 2013 03:39 PM
70Cutlass_408
June 24th, 2011 07:55 AM
