Customer supplied Holley 750
RPM port matched by Peyton Hunt
CNC’d Gen I Edelbrocks (Peyton)
10.6:1 Mahle piston
Eagle 6.125 rod
My stroker crank
Hyd Roller, .580 lift
Progression Ign Dist, FAST coil
93 pump
506hp/540tq
Ummmmm, done at 5300? What in tarnation? MORE CARB!
500 is nice, though. What cubes?
428. Cam is in kinda early, and I think it just ran outta air.
BUT, starting off at over 500tq outta make it a fun ride!! Going in a ‘79 TA in place of the original 403.
Great build. What duration range is that cam in? Huge torque, I would say Peyton's heads aren't too big for 428 ci, over 500 ft-lbs from 3000 RPMs. That means tire annihilation and has 500 HP at loafing rpm. I really should have had Mark build me one, great job as always.
Nice build Mark. This is similar to what I may upgrade the 374 in my 70 Supreme to in the near future. Question - how do you think this same build with the new SBO heads would compare? About the same or less or more?
Nice build Mark. Question - how do you think this same build with the new SBO heads would compare? About the same or less or more?
-Joe
Thanks. Here’s what I can tell you. I did virtually the same build with out of the box GEN III BB Edelbrock’s, and they made a little less torque, about 10 pounds, but about 8 to 10 more horsepower, and a broader range.
Small block head would probably make a little more torque like this, and maybe about the same horsepower as the bigger head. But, you’ll need a much larger dish in the piston to keep the same compression ratio.
