Another stroker small block
Old Jun 8, 2026 | 09:45 AM
cutlassefi's Avatar
Customer supplied Holley 750
RPM port matched by Peyton Hunt
CNC’d Gen I Edelbrocks (Peyton)
10.6:1 Mahle piston
Eagle 6.125 rod
My stroker crank
Hyd Roller, .580 lift
Progression Ign Dist, FAST coil
93 pump
506hp/540tq
Old Jun 8, 2026 | 12:05 PM
70sgeek's Avatar
'72 Cutlass ragtop
Old Jun 8, 2026 | 12:09 PM
fleming442's Avatar
Ummmmm, done at 5300? What in tarnation? MORE CARB!
500 is nice, though. What cubes?
Old Jun 8, 2026 | 12:43 PM
cutlassefi's Avatar
428. Cam is in kinda early, and I think it just ran outta air.
BUT, starting off at over 500tq outta make it a fun ride!! Going in a ‘79 TA in place of the original 403.
Old Jun 8, 2026 | 04:26 PM
Mr Nick's Avatar
Finally dropping off my block to the builder next week for a similar build. I believe he's actually doing two stroker SBO's at the same time.
I'd be happy with those numbers.
Old Jun 9, 2026 | 06:00 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Great build. What duration range is that cam in? Huge torque, I would say Peyton's heads aren't too big for 428 ci, over 500 ft-lbs from 3000 RPMs. That means tire annihilation and has 500 HP at loafing rpm. I really should have had Mark build me one, great job as always.
Old Jun 9, 2026 | 06:23 AM
cutlassefi's Avatar
Who’s your builder?
Old Jun 9, 2026 | 06:49 AM
GEARMAN69's Avatar
Very Nice ! Love it
Old Jun 9, 2026 | 02:16 PM
OLDScience's Avatar
Block? Bore? Sroke?
Old Jun 9, 2026 | 02:24 PM
71 OLDS's Avatar
Nice build Mark. This is similar to what I may upgrade the 374 in my 70 Supreme to in the near future. Question - how do you think this same build with the new SBO heads would compare? About the same or less or more?
-Joe
Old Jun 9, 2026 | 05:20 PM
cutlassefi's Avatar
Originally Posted by OLDScience
Block? Bore? Stroke?
It’s been stated a hundred times on here, but here it is again;
Gas block
4.125 bore
4.00” stroke
Old Jun 9, 2026 | 05:24 PM
cutlassefi's Avatar
Originally Posted by 71 OLDS
Nice build Mark. Question - how do you think this same build with the new SBO heads would compare? About the same or less or more?
-Joe
Thanks. Here’s what I can tell you. I did virtually the same build with out of the box GEN III BB Edelbrock’s, and they made a little less torque, about 10 pounds, but about 8 to 10 more horsepower, and a broader range.
Small block head would probably make a little more torque like this, and maybe about the same horsepower as the bigger head. But, you’ll need a much larger dish in the piston to keep the same compression ratio.
Old Jun 9, 2026 | 06:41 PM
Mr Nick's Avatar
Who’s your builder?
CP Motorworks in WI.
Old Jun 10, 2026 | 04:32 AM
SY2455's Avatar
70 442 W-30
Super nice build and outcome, curious about the oil pressure. Is it a default reading on the dyno?
Old Jun 10, 2026 | 05:05 PM
cutlassefi's Avatar
Mechanical gauge, not feeding thru the dyno.
cutlassefi
Apr 9, 2026 05:56 PM
oldsmoboogie
Feb 15, 2026 05:11 PM
cutlassefi
Nov 24, 2022 06:45 AM
Magna86
Jan 15, 2021 08:44 PM
cutlassefi
Sep 24, 2016 03:05 PM
