Something a little different
Old Nov 13, 2024 | 01:15 PM
cutlassefi's Avatar
I thought I’d post this for the simple reason stated above, something a little different.
One of my upcoming builds is, drum roll please, a turbo charged 455 for a 1976 23’ GMC Motorhome!
Custom Racetec .040 over 2618 pistons, 40cc dish, 8.4:1
New Gen III Edelbrocks
Hyd roller
Edelbrock O4B intake(scrapping the stock low profile iron one)
Terminator X TBI set up for flex fuel
For right now we’re going to try to use the previous manifolds and turbo setup that was on it when he bought the vehicle. We’ll see.
I tried talking him into doing a big block Stroker, low compression that he could run on 87 octane anywhere. But he was pretty hell-bent on using the unit that came with a vehicle. So, here we are. It’ll be a little while before I get it on the dyno, but any progress I’ll post here whenever possible.
Thanks guys!
Old Nov 13, 2024 | 01:52 PM
Oldsguy's Avatar
Past Administrator
Interesting start, I think I'll follow this one...
x2
Old Nov 13, 2024 | 02:09 PM
I'll tag along.
Old Nov 13, 2024 | 02:55 PM
4R5's Avatar
4R5
Mark, what are your HP TQ goals? How much boost? Is the turbo a recent design or from one of those '80s kits that were the rage back then, especially for SBCs.
Old Nov 13, 2024 | 03:04 PM
Don't let my friend Bill see that...
Old Nov 13, 2024 | 03:11 PM
cutlassefi's Avatar
I’m pretty sure I mentioned it to him already. He thought about it for a second then…..
Old Nov 13, 2024 | 03:23 PM
cutlassefi's Avatar
It should make 400hp-500tq on motor only. Boost is going to be held to 5#’s or so. Not going to push it. I don’t think the turbo is very efficient anyway.
Old Nov 14, 2024 | 06:04 AM
Oldsguy's Avatar
Past Administrator
Just a thought and sharing a moment. The other day I heard what could have been the whine of a supercharger coming from a Dodge Challenger across the road from me at an intersection but the hood was original and I suspected there was no room for one so I thought, "maybe it's a turbo, they whine sometimes like that too". As I crossed the road and drove by the guy I notice his window was down and hollered "Spin it up!" as he started to take his turn crossing. So he did and man did he light up the tires! What a show! Maybe it was a turbo, maybe it wasn't.
Old Nov 14, 2024 | 07:29 AM
SteveDB's Avatar
Stuck in the 80's
That motorhome is front wheel drive with tornado transaxle right? They have quite the cult following. Cool project, thanks for posting.
Old Nov 14, 2024 | 07:30 AM
cutlassefi's Avatar
Correct, and yes they do.
Old Nov 14, 2024 | 01:50 PM
brotherGood's Avatar
ProCharger maybe?
Old Nov 19, 2024 | 12:30 PM
Alaska442's Avatar
I bought a supercharged roots type 455 from a GM motorhome that was locked up. It had a B&M style 177 on it. Same type of build you are doing with the engine, gen 2 edelbrocks and it was nearly new.
It over heated badly and warped one head and caused it to lock up. Be wary of a supersized cooling system.
Old Nov 19, 2024 | 03:46 PM
Funkwagon455's Avatar
Subscribed, interesting.😊. Could we possibly get some photos of the GMC itself? Those things are all over the map with regards to quality. I’ve seen both stunning versions as well as “Cousin Eddie editions”
Old Dec 5, 2024 | 07:27 PM
gs72's Avatar
72Cutlass S
Subscribed.
Old Dec 28, 2024 | 09:16 AM
cutlassefi's Avatar
Close to dyno time;
Updated specs;
8.8:1 comp
Cam 227/234@.050 on a 113lsa
It'll be dyno’d NA first with an Edelbrock 750 VRS Carb.
Anyone want to guess power with manifolds? Headers?
Thanks.
Old Dec 28, 2024 | 09:26 AM
fleming442's Avatar
470/625
what hydraulic lifters are in it?
Old Dec 28, 2024 | 09:54 AM
cutlassefi's Avatar
470/625
Gaterman. And I think you’ll be about 10-12% high on your guess, but we’ll see!!
Old Dec 30, 2024 | 09:27 AM
oddball's Avatar
Gaterman.
Spill the beans, man! What's the scoop on those lifters, especially compared to the Comp evolution? Anyone else notice sizing variances with the Comp Evo or is it just me?
Old Dec 30, 2024 | 02:23 PM
CANADIANOLDS's Avatar
Post up the variances you found.
Old Jan 1, 2025 | 10:59 AM
olds_freak's Avatar
They look like the Crane lifters to me.
Old Jan 1, 2025 | 11:00 AM
oddball's Avatar
It's been a few years so my memory is foggy. I'm pretty sure there was more than 1 thou variance between lifters in diameter and they were an extremely tight fit.
Old Jan 1, 2025 | 05:39 PM
you said the Comp evo’s have variances….now you say it’s been a few years and your memory is foggy? The evo’s are a new design.
Why bring up Crane… are they even around anymore?
if you’ve ever measured the lifter bores on an Olds, you would know they are all over the place. The lifter dimensions are the least of your problems
Old Jan 1, 2025 | 06:06 PM
cutlassefi's Avatar
Evo’s have been out AT LEAST two years, maybe a bit longer.
And Crane was absorbed by Comp, at least part of it.
Bill Gaterman (Gaterman lifters) worked at Crane for years, as did Brad A. Miller, founder and owner of BAM lifters. Each of them bought machinery and programs from Crane once they closed their doors.
Old Jan 1, 2025 | 09:55 PM
I don’t want to clutter up your thread with hearsay on variances..how about you start a new one to clear up the variance claim.
Old Jan 2, 2025 | 03:48 AM
cutlassefi's Avatar
I never said anything about variances, you and oddball did.
Old Jan 2, 2025 | 04:20 PM
I never said you did..you have an overactive imagination. even through this is your thread, you butted in to answer a question I asked of someone else …with a bunch of name dropping that meant nothing.
the fact is, there are no variance problems with the evo’s, for the Olds or any others.
that’s the end of it.
Old Jan 2, 2025 | 05:10 PM
cutlassefi's Avatar
Yes you did. you have a habit of not reading your own posts. I never said anything about variances, I just stated the Evo's have been out for at least 2 years.
"I don’t want to clutter up your thread with hearsay on variances. how about you start a new one to clear up the variance claim".
This was directed to me for some reason, not oddball. YOUR post, #25. Get it?
Old Jan 2, 2025 | 08:01 PM
exactly…I ASKED you to start a thread about the variance claim because you responded to my question to another person about a variance claim…understand?…I never said you SAID anything about variances…
I never asked you anything..you were being a Karen like usual..nobody asked who worked where or when or who does what with who . you went right into the drama .
Old Jan 3, 2025 | 04:49 AM
cutlassefi's Avatar
Uhh ok sure.
Whatever, moving forward.
Old Jan 21, 2025 | 03:14 PM
  #31
cutlassefi's Avatar
Preliminary base numbers.
Remember it’s getting a TBI unit so I didn’t spend a lot of time tuning it. However air/fuels were pretty good, high 12’s to 13 or so.
I’m still trying to convince him to bag the turbo route, but we’ll see.
Old Jan 22, 2025 | 06:17 PM
  #32
Fpcopo's Avatar
Which oil pump and spring did you use Mark?
Old Jan 23, 2025 | 05:03 AM
  #33
cutlassefi's Avatar
HV, purple spring. You have to add a few #’s to that number vs a mech gauge, it’s off a little.
Old Mar 11, 2025 | 05:23 AM
  #34
cutlassefi's Avatar
Final numbers were 452hp, 521tq (corrected) with the Terminator TBI. I’ll post the dyno sheet in a few.
Better yet I was able to talk him out of the turbo. I’ll explain more on that as well.
And yes, all done on 87 octane, and a 2.500” exhaust, just like he’s going to run.
Old Mar 11, 2025 | 08:25 AM
  #35
GEARMAN69's Avatar
Final numbers were 471hp, 524tq with the Terminator TBI. I’ll post the dyno sheet in a few.
Very nice low compression 87 octane combo !
He could always throw NOS Cheater plate on and some 93 octane for the RV drags !
j/k
EarlSpilner
Dec 30, 2024 09:27 PM
Andrew Anatian
Jul 30, 2024 06:17 PM
Bozang1
Mar 6, 2016 06:50 PM
joepenoso
Aug 10, 2012 11:54 AM
1971olds350
Aug 31, 2010 09:36 AM
