PDA
View Full Version : Drivetrain/Differentials
Pages : 1 2 [3] 4 5 6 7
  1. 10 Bolt. 2.73
  2. G Body Rear End Swap
  3. Type O swap to BOP 8.2 posi
  4. 71 Cutlass 12 bolt axle question
  5. Casee and pinion bearings?
  6. Does This W27 Cover Fit My Rear End?
  7. Replacement 72 cutlass 10 bolt bolt in axles?
  8. 68' 442 rear end????
  9. 1970 type O, axel bearings?
  10. 1970 type O posi rear end?
  11. Heat build up in rear end?
  12. Ring Gear Pattern - Sanity Check!
  13. 3.23 open 1971 1972
  14. Beefed up 8.2 rear
  15. 10 bolt lengths
  16. B Body Type O 12/10 rear axle ID
  17. Ring and pinion gear set
  18. Differential Identification 63 Cutlass/F85
  19. Spider gears for open 8.2 BOP Diff
  20. 1965 442 cutlass pinnon gear
  21. Help me out 455 gear options 3.23 or 3.42 ?????
  22. Rear End Upgrade Cost, 8.5 GM 10 Bolt
  23. Stock 12 Bolt "O" Axle hp/tq limit?
  24. Rear end question
  25. Axle movement
  26. 12 bolt ?
  27. 71 w-30 rear id
  28. Slip Yoke Lube Questions
  29. Need help identifying rear end in 70 Cutlass
  30. Which Powertrax Products?
  31. 70 Ring gear question
  32. Help ID Gear 71 AntiSpin
  33. Moser Rear End For 1967 Delmont 88?
  34. Pulsating vibration starting at 50 mph
  35. Swapping 68 Chevy 12 bolt in place of "O" Type--upper control arm length issue
  36. 67 rear end
  37. Driveline length 70 Cutlass 350/TH350--swap to Muncie and Chevy 12 bolt
  38. Canadian Type "C" diff
  39. U-joint question?
  40. Anyone know of a decent
  41. axle identification
  42. Which spedo-gear?
  43. 68 442 O-type axle bearings
  44. 75 h/o posi rear axle
  45. Rear Axle Bearings w a freezer, oven and a breaker bar
  46. Yoke Question?
  47. 69' "O" posi ??
  48. Search differential case
  49. "O" axle retaining plate
  50. Rear gear ratio
  51. I broke my '63 F85.
  52. Rear axle bearing housing nut/stud.... help
  53. Which Posi type?
  54. Trying to determine gear ratio
  55. I want the perfect rear end set up! PLEASE HELP ME!
  56. 72 cutlass diff identification
  57. 68 supreme new gears and posi
  58. Would you use these axles
  59. 8.2 vs 8.5, how do I tell?
  60. 68 cutlass rear axles leaking
  61. Driveshaft length question
  62. U Joint question
  63. 1953 Oldsmobile Pinion problems
  64. Correct differential code
  65. junkyard posi?
  66. Trying to decipher a limited slip.
  67. Another O-type question
  68. 12 bolt o axle
  69. 1971 Cutlass B – 350 – factory standard rear axle ratio?
  70. Gear-set, ok pattern?
  71. 71 Cutlass axle??
  72. Question about different 8.5 rear
  73. 67 Delmont 88 to 8.5" Caprice Differential
  74. What To Do With A 70 O Type 2.73 Non-Posi Olds Rear
  75. 72 Cutlass 10-bolt rear - which one is this?
  76. Driveshaft Question: Installing Chevy 12 Bolt & TH400 in 70 Cutlass
  77. 12 bolt vs. 9"
  78. Rear diff ratio advice
  79. Confused about measuring ring gear.
  80. 1970 Cutlass 8.5 10 bolt rear question
  81. Best choice to have new 3 series carrier/3:23/Posi unit put in or none of them?
  82. Rear end upgrade advice
  83. Driveshaft Destroyed!
  84. Sourcing U-Joint Strap Help
  85. Which gears to choose?
  86. rear end swap ???'s
  87. 67 Cutlass posi and 355 gear kit
  88. 1961-63 F85 driveshaft CV joint repair
  89. 12 bolt O-type ring gear spacer???
  90. Suggestions for conversion to a limited slip unit
  91. 70 cutlass posi rear end swap question
  92. Swapping rear end assemblies?
  93. Oil change in a diff without drainplug or cover
  94. 64 starfire positrac diff
  95. Rear ratio?
  96. Changing type O gear set from 3.95 to 3.08 or similar
  97. posi unit for 402227 rear end
  98. Differential ID, please!
  99. -60 Dynamic 88 driveline setup
  100. Driveshaft shortening
  101. GTO differential swap?
  102. "O Axle Posi Upgrade Options
  103. Corporate Rear end
  104. Uh oh!
  105. What is the difference between "O" type SE & S6?
  106. 71 Corporate axle question
  107. pinion nut re-installation
  108. Drive shaft / propeller shaft question
  109. Gearing up for gear swap
  110. Installing Chevy 12 Bolt in 70 Cutlass
  111. Rear Gear Ratio
  112. Please help identify this axel
  113. 10 bolt internals
  114. 2 Piece Drive Shaft
  115. Hurst Dual Gate Shifter question.
  116. 1972 12 bolt
  117. 66 cutlass rear axle
  118. 1970 442 clutch pack question
  119. Type O preload specs
  120. Carrier Question
  121. Slip Yoke Confusion
  122. Ring gear pattern
  123. Rear axle limited slip, ratio and 10 vs 12 bolt rear
  124. Drive shaft problem
  125. Traction bars for a 57
  126. Looking for Website with 68-72 Axle Ratio Codes
  127. 71 442 Posi Identification SS 1040
  128. HELP to ID--Chevy 12 Bolt for my 70 Cutlass--Pics attached
  129. '70 442 Rear Lower Control Arms
  130. What gear oil for an original 588 carrier and 3.42 gear?
  131. g-body 8.5 rear from open to posi
  132. Axle bearing installation
  133. Stock Olds 10 bolt 8.2" cone LSD (posi) bottom of cone to case clearance question
  134. Detroit Locker
  135. Reputable Drive Line shop in DFW area
  136. "late model" rear end for 40 Olds
  137. "O" Type Rear With No Numbers On Carrier---"What's up with that?"
  138. Turbo 425 final drive gearsets
  139. O rear Posi
  140. 26 spline axel with big Chevy bolt pattern
  141. Differential Bushing question
  142. Gears Tires and Four Speed
  143. 1970 Cutlass S 'vert
  144. Trade 3.91 for 3.23 gears o type
  145. One Piece Bearing/Seal Pros and Cons
  146. POSI Rearend -Corvette or TransAm
  147. Sandblast the housing?
  148. Keep the type O or change
  149. Rear end swap
  150. 1953 88
  151. 8.5" differential center section pin retaining bolt breakage
  152. need help decoding this differential
  153. Pinion Crush Sleeve for '71 corporate 8.5" Differential
  154. what posi carrier is this
  155. 10 bolt info
  156. 10 or 12 bolt
  157. Drive shaft
  158. 67 442 gears
  159. What gears
  160. 64 Jetstar 88 ate the the axle shaft
  161. What Tranmission yoke do I need?
  162. Corporate or Non-Corporate Axle
  163. Bent axel flange
  164. 72 442/Vista Cruise Rear Axle Difference
  165. 1964/98 differential code
  166. Upside down code stamping 1970 OLDS
  167. Mini spool swap 70 type O 12/10 bolt
  168. 71 supreme rear end ID
  169. 1970 posi rear
  170. 71 Buick 8.5 10-bolt into 66 Cutlass
  171. Car shaking
  172. rear end decode/strenght question
  173. Type "O" Rear Diff - Rear Axle Flange?
  174. 72-7 bolt posi rear
  175. Will this LSD fit?
  176. Figuring out rear gear
  177. 1967 442 post
  178. 67 and 75 drive shaft
  179. What diffs are interchangeable with the the Olds 442?
  180. Limited Slip and gears
  181. '54 rear, where to get parts?
  182. Strange vibration at 60mph
  183. 1966 jetstar88 oldsmobile.
  184. 1941 Olds drive shaft
  185. Richmond ring and pinion install DVD - who's next?
  186. Questions on rear end pricing and specs
  187. Driveline vibration
  188. Posi needed for 65 442
  189. Need help identifying this rear end
  190. Gears for a 9.375" Type O (full size)
  191. Rear End Ratio
  192. 68 442 axle bearing retainer plate
  193. 74/75 88 rears. what where available gear ratios when new?
  194. D88 Gearing?
  195. Corporate 10 Bolt in 1966 442
  196. Ford 9" in a 72 442 Convertible
  197. TM axle 68 442
  198. 69 rear end advice
  199. Pick n Pull rear end???
  200. 66 f85 rear end swap ?'s
  201. 8.2 or 8.5
  202. 68 cutlass 442 outer wheel bearings
  203. 72 Cutlass, rear end removal
  204. 69 Sport Coupe Axle Upgrade
  205. Chevy rear end in Cutlass
  206. Driveshaft u joint cap
  207. 1955 part numbers
  208. 1977 Olds cutlass 10 bolt gear swap
  209. Crush sleeve eliminator
  210. Ring & Pinion install Cd
  211. Help with olds rear end I.D. please
  212. 10 bolt 7.5 questions
  213. 10-bolt cover with 12-bolt ring gear?
  214. '72 S gear swap
  215. '70 442 U-Joints
  216. 83 old custom cruiser
  217. Axle Bearings
  218. 69 Cutlass Rear End Finish/color
  219. lungeing while driving at lower speeds
  220. TKO driveshaft length a body
  221. Axle spline question
  222. 9.3 Rearend Parts
  223. Rear axlecode
  224. 1968 SD code rear end- easy to remove posi carrier?
  225. 1968 HD 31 spline diff
  226. Rear axle ratio question
  227. Rear end for my 1966 f85.. will this work ?
  228. 1972 olds 98 dif swap to 1970 cutass
  229. Looking for Advice
  230. 70 o-type 12 bolt rear end
  231. Will a 73-77 Cutlass rear end bolt into a 65 Cutlass
  232. Bent Axle or bad bearing? - need help
  233. 1968 Cutlass Rear End
  234. Eaton differentials
  235. 10 Bolt Posi Seller's Ad How Much is BS?
  236. Gears and a mini spool for an O type, what works?
  237. 83 Hurrst 3:73 w/Lim slip fluid
  238. Rear Axle Stamping Question
  239. Pinion nut torque
  240. 1970 delta88 rear end, need help finding parts
  241. 1967 3.91 12 bolt stamp location?
  242. rear end info
  243. 1964 Ninety Eight Rear end
  244. Will thes Spindles and bearings fit? (1969 Supreme)
  245. proper driveshaft length
  246. What size diff in my '65 Cutlass?
  247. help with driveshaft
  248. Best / Easiest Way to Change Carrier Bearings
  249. Need help Identifing.
  250. which axle ?
