PDA
View Full Version : Drivetrain/Differentials
Pages : 1 2 3 4 5 6 [7]
  1. Whatzit 12 bolt posi carrier w/28 splines!!!
  2. Source for decode of Axle CASTING number
  3. WHICH TRANS TO GET
  4. Boxed lower control arms
  5. 1949-52 Olds rear ends. Looking for 3.23
  6. pinion seal replacement?
  7. Need help identifying this rear
  8. search continues/for posi carrier!!
  9. rear axle identifcation
  10. 87 cutlass rear end swap
  11. 69 cutlass rear end
  12. How many teeth on a starter?
  13. Driveshaft
  14. 350 Olds Motor and 10 Bolt Rear End
  15. Rear diff control arm bushing remover tool
  16. 8.5 axle differential
  17. o axle?
  18. REAR END QUESTION
  19. WILL 3.23 FIT 2-SERIES CARRIER??
  20. Any body in Norfolk/Virginia Beach, VA area that can work on Rear End?
  21. 69 cutlass swaping gears in my rear
  22. Which one to choose?
  23. What Rear Ratio to Use??
  24. Swayh Bar - Who ? Where ?
  25. posi 12 bolt indentification
  26. 72 Cutlass drive shaft ??
  27. 12 bolt posi chevy or olds????
  28. 7.5-8.5 rear axle
  29. help me choose the right auto trans
  30. How do you you safely pull an axel?
  31. weel hop
  32. 60 olds drive shaft
  33. 10 bolt strength with a big block
  34. 10-Bolt Rear Axle
  35. 69 cutlass rear axle in 70 cutlass
  36. Factory spacer cracked
  37. 1992 chevy caprice rearend switch with 1972 cutlass conv.
  38. 1974 Omega
  39. 12 Bolt ID Question
  40. 1967 F85
  41. A good place to look for posi diffs...
  42. 72 442 Rear Differential ID
  43. need help with a 1953 rear end.
  44. rear end gears
  45. olds rearend qustion
  46. front suspension change for 350to455 engine swap?
  47. Rearend Gears
  48. A guy wants to trade me rearends.Noob ?'s
  49. 1968 Cutlass Manual Steering Box Compatibility
  50. pulled axels and now nothing turns
  51. 1973 GTO to 1970 Cutlass 4-spd swap
  52. Engine Paint for 350 Diesel
  53. 61 f85 control arms?
  54. This can't be right
  55. Source for oem or reproduction bolts and fasteners
  56. which 10 bolt?
  57. front bearings
  58. Posi for my 57 Super 88
  59. Best Rear Ratio for 455 w/ OD Tranny?
  60. 12 bolt posi
  61. steering box
  62. wipers
  63. Switch pitch availabilty.
  64. Driveshaft thoughts?
  65. 40 engine
  66. Where to get an axle?
  67. 1965 Delta 88 Differential Cover Gasket
  68. bop 8.5 3.73 gears
  69. Mystery Posi
  70. GM Type 1 question
  71. Axle Vent Blowing Out Fluid
  72. Axle installation and Lube.
  73. !955 hydramatic
  74. 1987 cutlass rear end!
  75. Vista Cruiser Rear axle bearing
  76. Axle Installation
  77. Axle removal
  78. Anyone with a 1969 Chassis Service Manual?
  79. What came stock?
  80. pulley interchangibilty for 324 with air/steer.
  81. Chirping sound while decelerating
  82. Pinion Nut and Torque Specs
  83. Switch pitch question ...
  84. Rearend Questions
  85. Driveshaft question
  86. wanted more speed
  87. Best choice- Corporate 10 bolt or O?
  88. Rear end question
  89. 63 Dynamic 88 Wheel help
  90. 10 bolt 8.5 differential open to limited slip
  91. 1970 442 W30 Rear End ID Help
  92. couple of quick rearend questions
  93. Need to ID rear end
  94. Problem w/ 8.5" C-clip axle
  95. ford 9
  96. How do I adjust speedo?
  97. 1977 Cutlass rearend limited slip????
  98. Fluid type
  99. Is something wrong here?
  100. Best Rear Gearing for an OD Transmission?
  101. '59 Olds Diff Questions
  102. Auto to manual Swap.
  103. gears in my 71 Cutlass?!?!?
  104. 12 bolt pinion yoke
  105. SPOOL HELP
  106. clutch set up
  107. Differential swapping
  108. Drive shaft TH350 vs. TH400
  109. auto to stick
  110. axle bearings
  111. Guys, I need your opinion.>>>
  112. will a rearend from a 73 grand prix fit my 72 cutlass?
  113. axle bearing retainer
  114. I need to rebuild '62 Starfire differential
  115. rear end leak
  116. Fat 50's affecting my driving?
  117. how wide is a rearend from a impala 1996 ss
  118. 12 Bolt Rearend - Help?
  119. Speedometer cable
  120. WANT TO CHANGE MY 12 BOLT O TYPE OPEN 2.56 TO POSI 3.42
  121. 1965 Delta 88 Diff.......
  122. '68 Tilt Column Repair
  123. 71 cutlass posi unit?
  124. housing bushings
  125. Speedometer
  126. Spring cup specs
  127. 400 TRANS.
  128. 71 olds 442
  129. Gear Ratio Recommendations
  130. Changing Differentials
  131. 1969 El Comino 12 bolt to 1969 Cutlass S. Swap
  132. chevell to cutlass?
  133. Rearend for a 57
  134. Gear swappers near Rocherster,NY
  135. A-body interchanging differentials?
  136. posi unit
  137. Differential Help
  138. 12 bolt vs. 9 inch Ford Rear end.
  139. Rear Axle Tube Spun
  140. Advice on 4spd Transmissions
  141. I need some Expert Advise!
  142. code question
  143. 8.75 rear end
  144. factory gear ratios?
  145. gears
  146. type 'o' question
  147. U-joint removal
  148. Rare (not desirable?) 68 cutlass conv.
  149. olds buckets
  150. 455-th400-??????
  151. SSII Rally Rims on craigslist NH
  152. how do i decode my rear end??!!
  153. can someone point me towards a link...
  154. 3 rear ends....$200 bucks. Buy them?
  155. rear end question ???
  156. What rear end in a 62 Full size
  157. these worth anything?????
  158. 65 olds delta 88 rear axle interchange
  159. Rear Ends 101
  160. TY code type "O" 12 bolt info needed.
  161. Rear end help
  162. 67 to 71
  163. Dropped spindles for a 1953 Olds?
  164. 1950 belhousing wanted
  165. gear ratio question
  166. ID'ing a nice rearend
  167. HELP!! Restoring 68 442 w/Axles Rusted into place
  168. Anyone know a source for new stock steel wheels in 15" 5 on5?
  169. Questions for '71 Cutlass Supreme differential
  170. 70 Ralley HELP!!
  171. 65 Cutlass Rear End
  172. rear end?
  173. rear end swap
  174. what you thinking about this pattern???
  175. 10 Bolt Posi Availability
  176. which gear oil ????
  177. need help to id
  178. Need Help!!! : 67 Cutlass Brake Conversion/rear Axle Removal...
  179. my 12 bolt
  180. 1987 Cutlass Transmission
  181. 1971 B-body (Delta/98) info
  182. cheap gears, where can i get some?
  183. IS it possible
  184. gear ration of a 1970 442?
  185. "O" Type rear axle
  186. 1955 rear end ratio
  187. can i use 68-72 r.upper arms on a 65 442
  188. need i Aluminum Rear-End cover(Girdle)???
  189. looking to trade my type "o" rearend for chevy 12 bolt...
  190. Rear Differential
  191. 81 ninety-eight
  192. Question about Hydramatic Slim Jim
  193. 78 delta 88 rear-end.
  194. stabilizer bushings 1964 olds98
  195. whats the difference between olds 10 and 12 bolts???
  196. 57 olds rear end: sta wag vs sedan ratio
  197. 57 Center Bearing Housing Broke - HELP!
  198. tire size
  199. differencial housing lengths
  200. what is easier to powerbrake
  201. Overdrive Transmissions
  202. 1:75 to One?
  203. Rear fluid capacity?
  204. Rear exle numbers?
  205. BEAUTIFUL '60 grille
  206. Oldsmobile/Pontiac 9.3" C Axle --- Help!
  207. Is a 66 Jetstar 2dr rearend same as Cutlass?
  208. b body posi?
  209. 4 Sale - 1 Posi - 1 open
  210. Dropping a 66 Toronado...
  211. 1988 cutlass supreme
  212. rear axle website
  213. Rear end choice
  214. G body vs A Body Rearends
  215. 83 Cutlass Supreme rear end mods
  216. Wheel Size For a '65 olds 442
  217. 3.08 gear
  218. 64 and 65 Starfire Wheels
  219. Bolt Spacing?
  220. Bolt Spacing?
  221. 70 Supreme Gear
  222. what diff will fit?
  223. ring &pinion
  224. bushing chioce
  225. rear end rebuild 72 cutlass
  226. Rear End Ratios
