Pinion Nut and Torque Specs
Old Aug 16, 2008 | 01:54 PM
mcutlass1969's Avatar
Do you need to get a new Pinion nut after each time you remove it. I had to repair the pinion seal and ready to tighten it down. I know on fords it is recommended but not sure on GM. also what would be the torque spec on the nut as well as the cover bolts on a 12 bolt.
Old Aug 16, 2008 | 05:33 PM
Run to Rund's Avatar
A good idea to replace it, but you can clean and use blue loctite. There isn't a torque spec per se, because you tighten it until the crush sleeve is compressed enough to give the desired preload on the pinion bearings. The short cut if not disassembling the rear is to mark the pinion stem, pinion nut, and companion flange with paint and reassemble just as taken apart, and tighten the nut just a hair further than it was before.
Old Aug 18, 2008 | 09:59 PM
monzaz's Avatar
pinion nut
Peen/punch the nuts into the pinion threads This will guarentee the nut will not back off under hard torque accellertion bursts (burn outs...lol.) Jim
Good luck.
bob p
Jun 4, 2015 01:53 PM
Don Roberto
Apr 11, 2015 09:48 PM
1kool88
Drivetrain/Differentials
Oct 28, 2014 08:40 PM
ctreutel
Jun 26, 2013 04:01 AM
1973olds98
Aug 17, 2010 11:48 AM
