bushing chioce
Old Apr 5, 2003 | 04:45 AM
crank.it's Avatar
Post
can any one give some advice on bushing replacement,to use poly or the stock rubber,i've been told the poly makes the ride to stiff and will turn the car into a rattle box after 10'000 miles....72 cutlass convert.....thanxxxxxxxx
Old Sep 13, 2007 | 09:23 PM
monzaz's Avatar
bushings
This a old thread too but worth discussing.
poly bushings will make the car stiffer... and stock rubber will give you back your stock softer ride.
poly pluses-
-stiff in turns and prevents body and suspension roll.
-handles torque better
-pretty much lasts forever
-cost is relatively cheap
poly minuses-
-transfer more of the shock of the road through the suspension
rubber pluses-
- soft factory ride
- for show they look stock
- keep down noise being transfered through the drive line
rubber minuses
- does not transfer torque as well as poly
- body sway more in turns
- has a much shorter life and breaks down with heat and oil etc.
- cost tends to be more than poly ??? yes that is correct. at least compared to moog.
I am sure there are more opinions...Jim
Old Sep 14, 2007 | 07:32 PM
Originally Posted by monzaz
This a old thread too but worth discussing...
Poly on the rear control arms is a problem. The typical GM 4-link rear suspension causes the control arms to twist slightly as the suspension moves. The factory rubber bushings are soft enough that they absorb this twisting with no problem. Poly bushings are much harder and will cause the rear suspension to bind. The solution is to use the upper arms that have ball fittings at the forward end. This solves the binding problem.
Old Sep 14, 2007 | 08:52 PM
I redid the suspension on my car a few years ago and I ordered rubber bushings. I am still pleased with the ride quality and lack of road noise in my car. The only thing I have to do now is restore the interior and I will be set.
Wilson05
Suspension & Handling
Apr 19, 2009 12:09 PM
tim72
Drivetrain/Differentials
Apr 3, 2009 09:00 AM
The Stickman
Dec 17, 2008 04:18 PM
maskinen
Nov 5, 2008 11:31 AM
miti12
Alero
Jul 27, 2007 09:56 PM
