What came stock?
Old Aug 21, 2008 | 06:52 PM
The_Jeremiah's Avatar
What came stock?
Hey, my 69 cutlass 4-door has a 10 bolt rear axle. Someone broke the tag off, and now i cant tell what i have, what would have been in the rear end from the factory ? its a 350 bolted to a th350, and is all original to the car, along with the fact that its a 10 bolt open diff. Looking to put a spool or mini spool in it. any help would be great, thanks!
Old Aug 21, 2008 | 09:21 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
If you're going to drive it on the street, you don't need a spool.
Spools are to make both wheels lock up and go straight all the time.
Old Aug 22, 2008 | 09:03 AM
Putting a spool in your car is a bad idea unless you plan to race often.
Old Aug 22, 2008 | 02:52 PM
Bluevista's Avatar
Registered
Isn't the axle code stamped into the axle tube? Look for some letters and numbers on the right top forward of the vent if it's like a '71.
Allan
Old Aug 22, 2008 | 08:37 PM
mugzilla's Avatar
is Fast Enough ...
Open the cover ...
Count the gear teeth ...
Old Aug 23, 2008 | 06:07 AM
kevdog442's Avatar
Member
I think a 69 should have had a 12 bolt. Your ten bolt may be from a later car.
Cameo White
Hurst/Olds
28
Oct 12, 2009 07:09 AM
craftsmen22
Sep 26, 2009 03:11 AM
ddusty1
Jun 16, 2008 12:01 AM
Nailhead 88
Feb 12, 2008 04:41 AM
falconsfan
Oct 14, 2006 01:39 PM
