70 Ralley HELP!!
Old Jul 7, 2007 | 12:31 PM
winterborn's Avatar
Question 70 Ralley HELP!!
I need information on driveshaft length for this car. It's a 4 speed car but is lacking a driveshaft. Information on either getting one built or finding a replacement would be handy.
Old Jul 7, 2007 | 06:46 PM
Oldsmaniac's Avatar
I believe a driveshaft from a standard cutlass with smallblock and turbo 350 is a direct swap....prob from years 68 to 72....Someone correct me if Im wrong.
Old Jul 8, 2007 | 08:56 AM
winterborn's Avatar
Thanks, Now to find one down here in New Mexico.
Old Jul 8, 2007 | 09:12 AM
Two things to be aware of. First, while all 68-72 A-body cars can be potential sources, the problem is that different rear axles can use driveshafts that vary by up to an inch in length. This may not sound like much, but if everything comes out on the short side the yolk can fall out of the trans, or at least leak.
Second, the automatic driveshafts use two concentric tubes with rubber in between. The manual trans driveshafts are solid.
Old Jul 8, 2007 | 09:44 AM
winterborn's Avatar
My car is a Four speed so I would need the solid driveshaft. Is the measurment from transmission yoke to rear end yoke. By yoke I mean the saddle that holds the universal joint. I think OPG had the transmission output yoke.
Frank T Kaluza
Old Jul 8, 2007 | 01:58 PM
Oldsguy's Avatar
Past Administrator
...the automatic driveshafts use two concentric tubes with rubber in between.
I didn't know that one. Great info. Now I are smarter!
Old Jul 9, 2007 | 08:01 AM
Oldsmaniac's Avatar
Even though your car is a stick the rubber connected driveshaft will work just fine for a street car and will be much easier to find. Also note that the yoke from a turbo 400 car is too large to fit the turbo 350, Jetaway, or Muncie.
Old Jul 9, 2007 | 04:13 PM
winterborn's Avatar
Thanks now I have a better idea what to check theyards for.
Frank T Kaluza
Old Jul 9, 2007 | 04:55 PM
texasred's Avatar
Tom Servo's Stunt Double
PM 70W30cars. He knows 70s and 4 speeds! Also knows a lot of Texas/New Mexico parts guys.
C.J.
69OldsCutlassS
May 1, 2009 01:02 PM
crazy'boutOlds
Apr 6, 2009 05:51 AM
marzgpt
Dec 4, 2007 07:41 PM
oldtimeclassics
Jul 27, 2006 01:15 PM
