what is easier to powerbrake
I currently have a 1978 Olds Cutlass Supreme with a 455. It currently has 308 gears, but I am considering swapping to a 410. Will it be easier to powerbrake a 410 rear end or a 308 rear end?
power brake
455 should not need any help power braking any gear...period. Gears...
gears are made to move the car quickly and get the car out of the hole off the line. To deliver maximum torque to the ground.
You will do a smokeier burn out with 3.08 gears because they will spin at a high rpm speed than the 4.10 gears through out the shift points.
Think now before going NO NO NO. Which gear gives you higher top speed?....... times up 3.08 will give your car a higher top speed then the 4.10 so if that tire can get your car to a top speed of 140 mph with in a safe rpm range when you do a burn out it is doing that speed if you go through all the gears spinning. 410 may only have a top end of 120 - 125 before the engine has had enough.... That is why. Faster tire speed MORE SMOKE.
The gears are made for the track and lower ET's quicker from point A to point B Period. Hope this helps you abit figure out what you want. If you need more info PLEASE visit us at JDRACE.COM for more helpful answers of differential questions. differential store and discussion forum CHECK IT OUT! Thanks, Jim
I can smoke the tires with the 307 and 3.42 gears, but I swapped from 2.73 about 6 months ago.
The 2.73's could smoke them too.
Hold the brake and push the gas, ease up off the brake just a bit and the car will jump a bit and should start smoking them up
RockAuto
Jan 23, 2013 12:14 PM
