will a rearend from a 73 grand prix fit my 72 cutlass?
Old Mar 31, 2008 | 10:58 AM
72Cutlass's Avatar
as title states...
thx
Old Apr 1, 2008 | 02:54 PM
don71's Avatar
same but different
Probably not, I don't want to steer you wrong. What you want for sure is a 68-72 rear.
The 73-77 is different animal.
Old Apr 2, 2008 | 06:51 PM
DennisG.'s Avatar
No. The upper control arm ears and spring perches are in a different location then the 72 and older.
Old Apr 18, 2008 | 09:24 AM
monzaz's Avatar
rears
even the shock mount are in different locations too. 73-77 are in the front
1964-1972 are in the rear
spring perches are slightly different too.
width is different
upper control arm mounts are different (already stated)
BUT the guts are interchangeable if that helps... you can remove the 8.5 guts and install them into your8.5 71 72 housing. Try that. Jim
djcrook73
Jan 30, 2012 07:08 PM
tnelson
Sep 9, 2010 05:57 AM
19684424speedconvertible
Aug 21, 2009 07:30 PM
