65 olds delta 88 rear axle interchange
Old Sep 22, 2007 | 08:25 PM
sny74's Avatar
Post 65 olds delta 88 rear axle interchange
I bought this 65 olds delta 88 about 3yrs ago. It has a 425 cid under the hood. It ran great until, the rear axle gave me some problems. I took a look at it and the entire axle housing has expanded out at the axle shaft location. Right now I am in search of looking for a axle to interchange with and what year can I interchange with? Please help.
Old Sep 24, 2007 | 07:12 AM
Oldsguy's Avatar
Past Administrator
You might PM Monzaz with your question, apparently he missed this. He might have some information that would help.
Old Sep 24, 2007 | 09:57 AM
65-70 B-body cars (Delta 88, Impala, Bonneville, LeSabre) all have interchangeable axle housings.
Old Sep 25, 2007 | 08:56 AM
jhoppeolds's Avatar
65 Delta rear axle interchange
Pontiac and Chevrolet B-body rear axles will not interchange. The Chevrolet uses trailing arms mounted at a completely different angle than the Olds and has the springs mounted on the lower arms instead of the rear end. The Pontiac appears similar, but uses different lower arms in 65-68 (the arm is shaped like a clevis and the bushing is in the rear end instead of the arm) and also has a larger pigtail on the spring end. I also believe the axle is a few inches wider overall. 69-70 big Pontiacs have the Olds style lower trailing arm and spring perch but this axle is definately a few inches wider. I've never checked out the Buick axle interchange so I cannot comment on this.
Old Sep 26, 2007 | 02:16 PM
monzaz's Avatar
That is all correct. We are working on helping him find a rear either in his area or to maybe fix the one he has. Jim
Old Sep 26, 2007 | 02:17 PM
monzaz's Avatar
rear
Pontiac Starfire should work. I want to double check that though. Jim
Old Dec 3, 2007 | 03:40 AM
Kennybill's Avatar
So, how did u make out on the rear-end problem? 65 & 66 Olds used the "Pontiac" type rear-ends, changed for 1967 to 1970 but the 67-70 will bolt right in. The odd-ball was the Jetstar. Where r u located? Ken
Sir_Charles
May 23, 2013 08:23 PM
Sami
Drivetrain/Differentials
17
Nov 25, 2012 03:09 PM
Musclecarsdk
Mar 26, 2012 12:20 AM
Jetstar 88
16
Mar 15, 2012 06:21 PM
cutlasssupreme71
Feb 22, 2011 11:40 AM
