72 Cutlass drive shaft ??
Old Mar 10, 2009 | 10:09 PM
egknz's Avatar
1972 Cutlass Supreme 455
just replace my 350 olds with short tail 400 with 455 and longtail 400 trans in 72 Cutlass which drive shaft do I use ?? and how do I make it work ??
Old Mar 11, 2009 | 03:12 AM
ziff396's Avatar
They are getting hard to find as there wasn't all that many turbo 400 to corporate 10 bolt cars built in 71-72. (Not nearly as many as turbo 350 cars that is.) I got lucky and found one. It should measure 53 1/4 from center of u-joint to center of u-joint. You will also need a yolk (31 spline?) for the 400. Mine is being shipped as we speak, so I am not sure about the length of the yolk. Other option is to have your's shortened or purchase a new one.
Hope this helps.
Old Mar 11, 2009 | 03:14 AM
ziff396's Avatar
BTW mine is a short tail turbo 400 and corporate 10 bolt. 72 Cutlass.
Old Mar 11, 2009 | 10:18 AM
They are even harder to find than you think, since there were NO long-tail TH400 A-body cars ever built. As I said before, this needs a custom driveshaft.
Old Mar 11, 2009 | 02:03 PM
ziff396's Avatar
Joe is right. That is why I added that mine is a short tail. You could also swap tailshafts however, the driveshaft is still a tough one. I looked for 2 months!
Old Sep 10, 2009 | 01:17 AM
egknz's Avatar
paid a visit to Stan Hopkins in Dallas Tx , they got it done !! 455 with longtail 400 in 72 Cutlass with original 10 bolt rear end
Old May 14, 2011 | 11:43 PM
projectheaven's Avatar
I probably won't get a reply but how long was the driveshaft when you got it measured?
Old May 15, 2011 | 07:30 PM
507OLDS's Avatar
I parted an abortion car 2 years ago.It was a 72 442 with a 455 & a long-tail TH400,from a Delta.I have the shaft from that.Not the way I would do it though.The long tail makes a tight fit under the A-body floorpan,and that's if you can get the driveline angle correct,so you don't have any vibrations.
johnnyjaws
Drivetrain/Differentials
Sep 4, 2014 12:07 PM
mdekker
Aug 18, 2013 08:30 PM
Frogge467
Mar 24, 2012 11:09 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
68conv455
Apr 11, 2008 11:48 PM
