weel hop
Old Feb 24, 2009 | 04:08 PM
jensenracing77's Avatar
weel hop
my rallye 350 will wheel hop if i try to spin the tires. when i restored the car i had a non original 3:91 rear end in it. 3 years ago mondello wanted my 3:91 and like a dummy i put the original 3:42 rear end back in without putting new bushings in it. could this cause the wheel hop? if not what could cause this? the bushings look good but i know that don't mean much.
Old Mar 1, 2009 | 05:26 PM
monzaz's Avatar
wheel hop issues
Many things can cause wheel hop in the rear of the car.
BUSHings rubber and or weakened rubber.
Shocks and or shock
pinion angle
springs
tire pressure and or compound
All can cause or add to problems.
Old Mar 1, 2009 | 08:22 PM
MN71W30's Avatar
Shocks and or shock
pinion angle
springs
Good advice!
If it didn't do it as much with the other rear end it may point towards the bushings. I have had good luck with no hop bars that change the pinion angle, but new bushings will probably help alot. Summit sells them in a kit. I have used a trade size 3/4" hole saw to drill the cores out of the old bushings and remove the rubber before trying to remove the outer steel core shell.
Old Mar 17, 2009 | 04:53 AM
70_CS's Avatar
torque machine
latter bars should help to plus look pretty ba
67flamedcutlass
Dec 19, 2019 07:54 AM
w-31cutlass
Suspension & Handling
16
Sep 12, 2011 08:58 AM
mugzilla
Tech Editor's Desk
Nov 2, 2008 09:25 AM
mugzilla
Tech Editor's Desk
Oct 16, 2008 11:26 PM
