71 cutlass posi unit?
Old Mar 1, 2008 | 09:04 AM
gumbyssfakee's Avatar
hi i have a 71 cutlass 4dr and id like to put in a posi but cant tell if the rear is an 8.2 or 8.5. all of the numbers on the rear have been worn away. how can i find out what i have without these and hopefully without opening the rear. also any sugestions on where to get a good unit in the 400-500 dollar range would b appreciated
Old Mar 3, 2008 | 11:35 AM
sklbndt's Avatar
Check on the front and back of the axle housing on the passenger side. It should be there....I know it seems like it's worn off but mine did as well. Lots of wire brushing and you should reveal a stamped code about 1/4 inch high. If on the rear of the axle housing it will be upside down.
Old Mar 21, 2008 | 06:18 PM
monzaz's Avatar
1971 olds reare diff ID.
You can check www.JDRace.com in the rear ID section. The 1971 8.5 has 2 straps and 4 bolts that hold the u-joint in place. The 10 bolt 8.2 has 2 u-bolts and 4 nuts that retain the ujoint in place. That should help
And of course this must have 10 bolts on the cover.
If you have a true olds 8.5 the rear cover will be round and have a passenger side bend /ripple in the upper 2 oclock position . (reference picture)
Some Buick 8.5 were put under the olds rears also which have covers that look almost like the 8.2 covers BUT they do not interchange because the 10 bolt pattern for the cover is slightly different. this cover has 3 and 9 oclock scallops in the cover like most 8.2 rears.
Hope that helps
Old Apr 14, 2008 | 02:21 PM
tpssonic's Avatar
8.5?
Hi,
I'm new to this forum and I have what I think is an Olds posi diff. Can someone tell me if this is an 8.2 or 8.5? If it is an 8.5, is it as strong as the other (Chevy) 8.5s and are part available? Most 8.5s I see have the "full" tabs at the 5 o'clock and 7 o'clock positions- not the BOP scalloped tabs. Thanks,
Tony
Old Apr 15, 2008 | 06:14 AM
tpssonic's Avatar
monzaz,
So the above pic is of an 8.5? That is what I have. The tabs at the bottom look like those of a BOP 8.2- that is what is confusing to me. Mine is a posi and has had 3.42 gears in it (not original). Being that it has 3.42s (using the driveshaft-turning method), I don't think it could be a 8.2. It has "407296" on the pig near the pinion as well as "CFD" (I think) , a big "CE", a "4" (again, not for sure) and has "C19" on the axle tube. Thanks for any information on this rear as there is very little information on this style of differential in the other GM rear end sites. All of the other sites do not mention this unit.
Is this a strong unit? I will be putting it behind a roller cammed 455 Pontiac in the near future.
Old Apr 18, 2008 | 08:51 AM
monzaz's Avatar
olds 8.5
OK- Well let me tell you...A true olds 8.5 rear is a tough id in the junk yard.
The picture supplied is the olds 10 bolt 8.5...AND yes it does look just like a 8.2 chevy rear...lol.
The buick 8.5 will have the scalops in the cover at 9 and 3 oclock and the triangular (normal casting) at 5 and 7 o'clock these casting triagle off the bottom of the housing casting are on every 10 bolt 8.5 all the way to 2008 trucks too. OLDS 71 72 were the only castings that were NOT.
WELL HOW THE HECK CAN i TELL difference?
-1. if the yoke has 2 straps and 4 bolts to hold the u-joint in the yoke
-2. must have bolt in axle 1971 1972 a-body
These are absolutes!!!
8.2 Olds will have U-bolts to hold the u-joint in .
and the axle will also have bolt in axles
If you supply pictures I will id it for you if you still are stuck.
here are some other absolute differences
-10 bolt 8.2 olds will have 27 spline yoke
-10 bolt 8.5 will have 30 spline yoke
10 bolt 8.2 axle shafts are 28 spline 60 degree spline
10 bolt 8.5 axle shafts are 28 spline 45 degree spline and WILL NOT FIT INTO A 8.2 SIDE GEAR UNIT. 8.2 WILL FIT THE 8.5 BUT WILL BE A BIT SLOPPY.
Hope this info helps there is always more to learn and again jdrace.com is all GM rear axle info questions are always welcome. I try to hit as many forums as i can in my free time to help. Jim
chevy 8.2 rears and c-clip axles and never had bolt in axle shafts
Old Feb 1, 2013 | 09:16 PM
nj_cutlass72's Avatar
ok so I am trying to figure out the gear ratio and from which car the rear came from to my 72 cutlass and ran into the same problem.
Is this a olds rear? although it has the chevy cover? it is 10 bolt, I am not sure if it's 8.2 or 8.5.
on the case there's large CE stamp, on the axle tube SA 0237 and casting # 407296.. and on the bottom CFD
Old Feb 2, 2013 | 05:11 AM
monzaz's Avatar
10 bolt 8.5
The rear is a 1971 1972 10 bolt 8.5 rear
SA comes out to - 2.73 ratio
Open NON POSI
Jim
Old Feb 2, 2013 | 06:25 AM
Open NON POSI
Jim
thanks Jim
All along I thought it was a chevy rear because of the cover pattern.
I couldve looked at the manual regardless it may be original to my car. I wonder when was the fluid last replaced if ever.
I have now a 455 under the hood instead of 350 and the rear cant keep up or its not as responsive
Old Feb 4, 2013 | 05:24 AM
pics
more
Old May 17, 2017 | 07:36 PM
tomslik190's Avatar
Axle Bearing?
Sorry to revive an old post. I have the exact same rear (407296, CE, and CFD on the center casting) in my 68 GTO. IT must have been installed by a previous owner. Anyway, one of the axle seals started leaking, so I took the axle out and took it to a local shop for a new seal and new bearing. It had the one piece "captured" bearing (no separate race) and the shop replaced the bearing with a 2 piece bearing (with separate race) and put in a new seal. Once bolted back into the axle housing, the axle would slide in/out about 1/4" so something was not right. It did seem to slip in too easy. I took the axle out and took it back to the shop and they are sending it to a specialty driveline shop for repair. All I wanted was the same type of bearing put back on, and a new seal. I hear the "A9" bearing is the correct one. Is the A9 a 1 piece bearing? The local shop says the bearing they put on is an A9, so I'm a bit baffled. I thought this would be an easy job but its turning into a fiasco. Can someone provide pics of the correct bearing and part number? THANK YOU!
Old May 17, 2017 | 09:27 PM
The last ones I installed were one piece with a retaining collar. I can't imagine how a two piece bearing with an external race would work in a rear axle bearing application.
I searched for Timken Set9 and got this a picture, which is what the last ones I bought looked like.
Old May 18, 2017 | 02:57 PM
monzaz's Avatar
seal on the a9 set 9 axle bearings
Most likely the shop did not install the correct seal. They used a 2146 seal and the rear you have needs a 712146 seal which is .030 thick easy. SO that is the reason for all the end play...YOU must switch to the correct seal. We only use the timkin set9 and 712146 seal...they are the only ones getting even remotely close to the correct thickness on the bearing and seal. Jim
J D RAce
Old May 18, 2017 | 05:10 PM
tomslik190's Avatar
thanks
Thanks guys. I should know tomorrow if they ordered the right parts.
Old May 19, 2017 | 05:05 AM
monzaz's Avatar
wrong parts right parts...
Did you order timkin brand? If not you ordered the wrong parts...
Jim
J D RAce
Old May 19, 2017 | 04:20 PM
tomslik190's Avatar
Timken bearing in place. axle back in car. all is good. thanks!
Old May 21, 2017 | 09:52 PM
monzaz's Avatar
a9 set 9
I hope they are still making them good... Will see how long this one goes... Did you measure your end play on the axle?
deadbiker
Sep 3, 2012 08:11 AM
monzaz
Jul 21, 2010 11:47 AM
projectheaven
Drivetrain/Differentials
Feb 5, 2008 10:08 AM
