which gear oil ????
Old May 25, 2007 | 02:54 AM
STLCRZY's Avatar
which gear oil ????
jjupiiiaajee from germany
guys.... i have question about the gear oil,what oil you think can i use, the only brand that i found quickly here in germany was from valvoline:
75/90
80/90 or
80/140
(with slip additiv)
or maybe another brand????
I will use the car(65 olds conv.455 cui) for a weekend cruiser only in the summer with a lil tire fire action..... the gears are from richmond 3.42:1 with a overhault auburn posi.
best regards
denis
Old Sep 4, 2007 | 10:26 PM
monzaz's Avatar
Oil reccommendations
Well Denis, That Auburn unit must have limited slip additive for sure. If it is aftermarket Auburn bought with in the last 4 years you should use there additive ...because they will not warrenty it if you use any other.
Any of the gear oil is fine EXCEPT SYNTHETIC. friction limited slip units are found not to work as effeicently with the syn fluid. Too slippery makes the clutches and cones slip too much causing actally more heat and wear.
So use any good mineral base Gear fluid with a Limited Slip Additive and you will be good for a while. Ok? Jim J D Race.com
JPMDaddy
Jan 14, 2019 08:41 PM
jpc647
29
Sep 8, 2017 09:02 PM
rustycragars
Dec 25, 2016 06:06 PM
thomaswatk
Mar 22, 2007 01:31 PM
