rear end swap
Old Jun 12, 2007 | 10:46 AM
sscutlas's Avatar
rear end swap
i just purchased a 1986 cutlass, and i wanted to know if a rear from an 80's model camaro will work in this car.
Old Jun 12, 2007 | 11:12 AM
The suspension design is completely different. The housing won't bolt up.
Old Jun 13, 2007 | 07:07 AM
sscutlas's Avatar
thanx for the info
Old Sep 4, 2007 | 10:20 PM
monzaz's Avatar
rears
Not to mention a totally different size ring and pinion...UNLESS you have a 442 or a GN rear under your car then the guts from that rear will bolt right in. 1970-1980 rears were 10 bolt 8.5 corp rears still used today under 1/2 ton trucks and SUVs. 1990 and newer are 30 spline and the 1999 and newer trucks have bigger carrier bearing now too. BUT all the gears will interchange. Jim
350TurBRO
Sep 12, 2014 11:52 AM
scrappie
Drivetrain/Differentials
Jul 25, 2009 06:55 PM
oldjunk
Apr 26, 2009 10:26 PM
olds cutlass
Apr 9, 2009 05:44 PM
loosecannon39
Feb 13, 2009 03:34 AM
