1968 Cutlass Manual Steering Box Compatibility
Old Dec 9, 2008 | 10:32 AM
MurphTypeR's Avatar
I have a 1968 Cutlass 2-door with power steering and want to change it to manual steering anybody know if a s-10 manual box will work? If not what will?
Thanks.
Old Dec 10, 2008 | 05:27 AM
Oldsguy's Avatar
Past Administrator
Whatever you change to, you may have to modify the pitman arm on one end or the other depending upon which one you use. If you use the arm from the box, you may have to cut off the end and have it replaced with the end from the pitman arm in the car; or if you use the arm from the car you may have to cut off the end at the box and use the one which cam with the box. Also, you may have to modify the length of the pitman arm as well. I had to do this when I converted from power steering to manual steering on a '69 Delta. I think I used a manual box from a '78 Omega (or maybe a Buick counterpart to that can't remember).
Old Dec 10, 2008 | 06:08 AM
Try Rock Auto Parts. They might have the manual steering box for your car.
http://www.rockauto.com/
dacutty
Jan 22, 2014 12:59 PM
jensenracing77
Apr 10, 2013 04:26 PM
therobski
Feb 12, 2012 01:06 PM
olds70supreme
Jun 30, 2011 07:35 PM
tarheeldoc
Sep 7, 2007 05:31 AM
