Axle removal
axle removal
Well, with out any help from the Olds "experts", I removed the axles with a slide hammer.
NOW- Could anybody direct me on how to remove and re-install the bearings and seals???
Any help???
Kevin
Any help???
Kevin
Replacement of the bearings, seals, and retainer ring requires a hydraulic press.
You figured out the slide hammer on your own. That's how you do it.
Most times it takes a machine shop to pull the axle bearings off and reinstall them and the seals. Money well spent just for the aggravation factor. At the very least you need a bearing press, and I don't know many folks have one in their garage. You MIGHT run up on a parts store that has one, but I'd say not likely at anything that's open on Sunday. Then there's the matter of having someone who knows how to use it...
Now, wasn't that slide hammer easier than fooling with those damn c-clips and lock pin? I hate those pins. Absolutely hate them.
Yah, the slide hammer itself would have been alot easier. However, I already had the pin and gears out looking for the c-clips! Oh well, next time I can turn 2 hours into 5 minutes!!
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
CUTLASS FREAK
Brakes/Hydraulic Systems
Sep 17, 2007 08:57 AM
CUTLASS FREAK
May 14, 2007 08:05 AM
