rear axle housing removal
Old Jul 28, 2010 | 12:47 PM
jet tech's Avatar
Question rear axle housing removal
I just pulled the yoke from my 72 cutlass differential for a seal replacement and as luck would have it the bearing is bad too and rust on shaft. I have new coils to install and I want to replace the upper link bushings too. So I might as well do every thing now I'm into it. How much trouble is it to remove the whole rear end axle housing and reinstall. I want to clean 38 years of crud also. Any tips or tricks to help. Thanks
Old Jul 28, 2010 | 01:08 PM
dc2x4drvr's Avatar
Let's see..remove brake fluid from M.C., disconnect the brake hose to rearend brake line, place jackstands under the axles, put a floor jack under the pinion, and remove the shocks, and control arms. Keep in mind that the floor jack is there to prevent the axle from pivoting down when you pull the last upper control arm bolt.
At this point I have a buddy steady the rearend, and pull it out the back on the jack.
You'll need a new upper rubber line, and it's easy at this point to just replace the hard line. BTW, the springs should fallout when you remove the housing.
Let us know how it goes..
Old Jul 28, 2010 | 02:09 PM
don71's Avatar
same but different
It isn't too bad of a job at all. You and a buddy could do this in an afternoon.
Remove the following...you all ready have the drive shaft out...
Lower shock mounts
Brake line on top of pumpkin, plug the line with something.
lower control arms
upper control arms
Springs will fall out like was stated.
If you drain the M C, you"ll have to bench bleed it again.
Ah yes, the dreaded parking bake cable. So this means the drums have to come off. A little trick to uninstall the cable is use a small hose camp to compress that claw like spring that holds the cable to the backing plate.
If you're replacing the shocks at this time the upper shock mount bolts can be a little challenging. If you have a chance, soak all the listed fasters above with your favorite wd40, pb plaster,liquid wrench etc, before getting started.
Good Luck.
Old Jul 29, 2010 | 10:19 AM
jet tech's Avatar
Ok thanks for that advice. Now for my next question. How do you get the axles out. The book (service manual) says remove C clips. I'm not seeing them. Are they located on the inside of the axle spline or some where else?
Old Jul 29, 2010 | 10:27 AM
dc2x4drvr's Avatar
No C clips on the original rearend, axles are removed by unbolting the bearing retainer (4 bolts).
Old Jul 29, 2010 | 11:12 AM
My442's Avatar
This is about 90% wrong.
The jack stands need to support the frame.
Get a service manual, as it will give you the proper steps.
Old Jul 29, 2010 | 02:47 PM
dc2x4drvr's Avatar
I was ASSUMING he already had the car on stands....I realize you only do things by the manual.
Old Jul 29, 2010 | 07:59 PM
jet tech's Avatar
Got the axles out, the proper tool (slide hammer) makes the job a lot easier. Next question, adjusting the side load bearing, and back lash. Any one have any experience at this?
Old Jul 30, 2010 | 05:13 AM
507OLDS's Avatar
A cheapie slide hammer to get the axles out = just take the brake drum & flip it around on the studs,so it is on backwards.Put a few lugnuts on with a few turns.This will let you slide the drum like a slidehammer,to pull the axles out.
Old Sep 8, 2012 | 11:04 AM
RetroRanger's Avatar
72 Olds CS
Old thread I know but I cant seem to get my axles out hoping to get some help.
my car is a 72 supreme AFAIK its the original diff I have a leaking axle seal I want to replace.
from reading on CO it looks like I need to have the bearing pressed off and on to replace the seal is that correct ?
Also another question, I took off the rear diff cover and drained it. I took out the pin and bolt and removed the top and bottom smaller gears in the diff, I couldnt slide out the side larger gears in the diff although they slid on the axle spline. I couldnt see any clip in there holding the axle, so I checked on here looks like there is no clip if it is a 72 axle just remove the four t bolts from the back plate and pull the axle. no luck the axle slides in and out a small amount ~1/16" or so and thats it. I didnt try brians brake drum idea yet (just read it) but I did attach a ~2 foot chain to two lugs and w 2 people swinging a hardwood 4x6 ~3 feet long and about 5-6 lbs we were able to really get some good pulls on it but it didnt budge....I attached some pics do I just need to slide hammer harder or is there a c clip im missing
the pics show the axle, the diff and the back plate bolts I removed
Old Sep 8, 2012 | 12:32 PM
foo's Avatar
foo
4 bolts on that retaining plate in the drum brake if you didnt get them all, the axles are usually stuck in there even after unbolting the 4 bolts it just needs a good yank, i managed to get mine out with a crowbar and a mallet
Old Sep 8, 2012 | 01:07 PM
Let's see..remove brake fluid from M.C., disconnect the brake hose to rearend brake line...
Or, if you're lazy like me, DON'T disconnect the brake lines. Instead pull the axle shafts, unbolt the backing plates from the axle housing (with brake lines still connected), remove the hardlines from the clips on the axle housing, unbolt the junction at the end of the rubber hose where it attaches to the center section, and hang the backing plates from the frame rails with coathanger wire. NOW drop the housing, leaving the brakes intact. No bleeding, no muss, no fuss, and no chance of dealing with rusted brake line fittings or bleeder screws.
Old Sep 8, 2012 | 02:38 PM
Nasty455's Avatar
XCELERATIONRULES!
Big gear head seems to know a lot about axles.
http://www.chevelles.com/forums/showthread.php?t=391212
Old Dec 2, 2012 | 08:13 AM
1970VistaCruiser's Avatar
Do I have to drop the cover and drain the rear fluid to remove my axles? I'm hoping the fluid level is below the axle height as to not get fluid in the tubes. I am only replacing the backing plates and updating the rear brakes to my 72 Supreme resto.
Any help?
Old Dec 2, 2012 | 09:43 AM
I believe the oil level is right the outer wheelbearing., cuz they are lubed by the rear end oil. Ill bet you could do it without removing cover if you removed the plug and made sure it wasn't a little over full then removed axles or maybe to be sure raised one side a little higher than the other and do that side. Then raise other side and do it. Of course top off when done. I also think I remember that it was practice to tilt rear end one way then the other and recheck level at plug to be sure some oil got to rear wheel bearings.
Old Dec 3, 2012 | 06:54 AM
monzaz's Avatar
Ideas
You can use a chain method and yank it that way... or you can use a old flywheel or old drum brake as a slide hammer deal too.
IF you remove the wheel cylinder you can get a steel rod in from behind and drive it out with a 4 pound sledge too. MANY ways to do it with back yard tools and items that might be laying around.
Good luck and let us know how you did. Jim
J D
Oldssupreme
Jul 31, 2014 07:58 PM
sbFALL63
Sep 29, 2011 02:05 PM
sbFALL63
Jun 4, 2010 05:36 AM
CUTLASS FREAK
Brakes/Hydraulic Systems
Sep 17, 2007 08:57 AM
CUTLASS FREAK
Drivetrain/Differentials
May 14, 2007 08:05 AM
