Changing Differentials
Old Feb 14, 2008 | 02:03 PM
Pfiffle's Avatar
I'm going to be swapping rears in my "76 Cutlass. It's going to be the same size, 8.5 10" also, but posi instead of the open I have on it now. Anyway, I've heard that I shouldn't torque everything down until I lower the car and put weight on everything first. Then tighten to proper torque specs. Is this true? Thanks.
Old Feb 14, 2008 | 07:58 PM
If you're talking about torquing the bolts on the suspension arms, that's correct. The reason is that the rubber bushings lock in when you torque the bolts and the arms want to be a normal ride height when you do it. The easy way is to jack up the rear axle while the car is on stands and when the springs are compressed, then torque the bolts.
Dshelvy
May 3, 2013 05:01 PM
Dshelvy
May 2, 2013 04:04 PM
Steve Wike
Mar 11, 2012 05:08 PM
coltsneckbob
Drivetrain/Differentials
Sep 9, 2009 03:15 AM
jrblanke
Apr 19, 2008 09:36 AM
