350 Olds Motor and 10 Bolt Rear End
Old Apr 2, 2009 | 04:51 AM
Sedrick's Avatar
I'm concerned about my rearend on my 85 Cutlass. I have a 350 motor and it's getting bored .30 over with the original heads shaved 10,000, 750 Holley Duel Feed Double Pump Carb and 292 Cam. My rearend is a 10 bolt 7.5 series. Does anyone else have similar components or comments that may ease my mind. I would like to put a mini spool in, so I can have positive traction. Any info is highly appreciated.
Old Apr 2, 2009 | 06:37 AM
The 7.5 is pretty weak. There are no inexpensive alternatives, however. Either spend the money for a 442/GN 8.5" or spend the money for a G-body 9" housing. The A-body axle swaps are not well engineered in my opinion and require rear wheels with custom offset. By the time you're done buying the control arms, the A-body axle, and the custom wheels, you might as well have just bought the right axle to start with.
What are you plans for the car? A spool is a really bad idea on the street unless you never plan to turn a corner. If you do, get a good limited slip unit.
Old Apr 2, 2009 | 08:30 PM
Sedrick's Avatar
I've located a 10 Bolt posi from a 71 Cheville with 373 Gears on the internet and would like to know if this would work on my G-Body Cutlass? Thanks for all replys.
Old Apr 2, 2009 | 10:27 PM
mugzilla's Avatar
is Fast Enough ...
I don't think it will bolt in ...
You might call carson auto wrecking (310) 835-7291 and ask about interchange ...
Old Apr 2, 2009 | 11:06 PM
88 coupe's Avatar
Junior Member
........ I would like to put a mini spool in ........
Better to use one of these: http://www.tomsdifferentials.com/catalog.asp?pg=40
I've located a 10 Bolt posi from a 71 Chevelle ........
Chevelle is an A body.
From post #2:
........ The A-body axle swaps are not well engineered in my opinion and require rear wheels with custom offset. By the time you're done buying the control arms, the A-body axle, and the custom wheels, you might as well have just bought the right axle to start with .........
The rest of the post is well worth reading.
Norm
Old Apr 3, 2009 | 05:50 AM
Go back and read my first post in this thread.
Old Apr 3, 2009 | 06:47 AM
Sedrick's Avatar
Ok, Thanks Mr. Joe I'll look further. I just plan on driving it on occasionlly around town.
67442nut
Jan 6, 2017 09:09 AM
350TurBRO
Sep 12, 2014 11:52 AM
RALLYE KID
Dec 20, 2013 11:58 PM
Qwik71442
Jan 4, 2011 02:26 PM
Aceshigh
Jun 10, 2010 08:16 PM
