3.08 gear
Old Apr 17, 2004 | 06:46 PM
Chuck C's Avatar
Post
I currently have an O type rear end with a 3.08 gear and I noticed in a forum that there are rebuild kits for the o type rear end. I'm not sure if I should look for a new rear end or rebuild the old one. I'm also not sure about how much difference a 3.42 (or higher) gear would make in my acceleration but it is a thought. The car is a weekend driver and sees very little highway but I do like the driveability it has now, however I think my goal is to get the car in low 13's high 12's. Any thoughts about my gear options. Thanks.
Old Jun 18, 2004 | 04:59 AM
Oldsguy's Avatar
Past Administrator
Post
Chuck, if you go to a numerically higher gear your acceleration will be greater. The downside is, with all other things staying the same, you will not have as high of a top end. Don't feel bad, by Delta has a type O with 2.73:1 gears. I barely turn 2,000 rpm at 70mph. This is an improvement I have been considering. Are those kits complete with new gears and everything? What is the price?
Old Jun 21, 2004 | 09:38 PM
Chuck C's Avatar
Post
I can't find the forum that I read about the rebuild kits for the o type dif. I gonna look around I'll post what I find.
Old Jun 25, 2004 | 04:26 AM
Oldsguy's Avatar
Past Administrator
Post
Ok, good luck and thanks for promising to fill me in.
Old Sep 5, 2007 | 02:35 PM
monzaz's Avatar
O type rebuild kits
I have them if you need . Pretty sure there are 2 different size 'O' type rears. I believe the a-body 'O' type is different then the full size 'O' type rear. I know the cover gaskets are different. Jim
J D Race.com
drjr56
Sep 9, 2012 08:05 PM
crazy'boutOlds
Jan 23, 2007 03:10 PM
69olds350
Nov 9, 2006 07:32 AM
mainedogg72
May 24, 2006 10:13 PM
70Supreme
Drivetrain/Differentials
Aug 19, 2003 04:24 AM
