One Piece Bearing/Seal Pros and Cons
Old Jan 8, 2016 | 07:29 AM
Mike H.'s Avatar
Regarding the '72 Cutlass 8.5 rear end, are there any pros/cons of the one piece bearing/seal combo over the bearing and seal being separate?
Thanks, Mike
Old Jan 9, 2016 | 08:40 AM
I am unfamiliar with the one piece design. The two piece design has two separate parts that are pressed on, then have a lock ring pressed on as well to help keep everything in place. I had a wheel bearing come loose once, so I would want to be sure the one piece design holds on as well as the separate pieces.
Old Jan 9, 2016 | 07:06 PM
monzaz's Avatar
no such beast
I do not think your looking at the correct parts for your 72 cutlass 8.5 rear end.
bearing is always separate from the seal
Jim
JD
VI Cutty
15
Apr 8, 2017 01:07 AM
olds 307 and 403
Jan 14, 2015 06:24 PM
1968CutlassSupreme
Mar 23, 2014 10:41 AM
Bernhard
Nov 22, 2012 07:12 PM
Vega
Sep 8, 2011 02:38 PM
