Need help identifying rear end in 70 Cutlass
Hello, not sure what I have and need help. 1970 Cutlass, it is a 10 bolt rear with 9.5 inch drums. The issue is the wheel cylinders appear to be wagon from my research, lines come in at an angle and bleeder at the opposite angle. I need wheels cylinders but parts house shows a different wheel cylinder with the line and bleeder pointing straight down the axle tube and they appear to be smaller cylinders. I can't find any cylinders that look like mine, but there are some that look similar online that say they fit a Vista Cruiser.
Is it possible to be a wagon rear end but having Cutlass 9.5 inch brakes instead of the larger brakes? Can I use the 7/8 bore cylinder in place of the larger cylinder since I have the smaller 9.5 brakes?
Hello, not sure what I have and need help. 1970 Cutlass, it is a 10 bolt rear with 9.5 inch drums. The issue is the wheel cylinders appear to be wagon from my research, lines come in at an angle and bleeder at the opposite angle. I need wheels cylinders but parts house shows a different wheel cylinder with the line and bleeder pointing straight down the axle tube and they appear to be smaller cylinders. Is it possible to be a wagon rear end but having Cutlass 9.5 inch brakes instead of the larger brakes?
bryndalfly
Sep 28, 2016 11:37 AM
2blu442
Mar 14, 2016 06:51 AM
mr_mahoney
Jan 31, 2014 03:53 AM
