Oil change in a diff without drainplug or cover
Old Aug 7, 2016 | 01:32 AM
Jandk's Avatar
In my 64/98 I want to change the oil in the diff, but havent got a gasket if taking the diff apart, but is it possible get a hose in through the filler hole and suck it out with a vacuum pump, of will I have to remove the complete gear??
Old Aug 7, 2016 | 01:44 AM
You could suck the oil out through the driain plug, or you could remove the cover and use RTV in place of a gasket.
Old Aug 7, 2016 | 02:02 AM
Jandk's Avatar
I dont have a drain plug, or a cover, that is why I ask. I only have the filler hole on the side of the diff, and before jaking up the car my question is if it is possible to get the in to the diff through te filler hole and down in side the diff enought to suck the oil out. But if the only way to go is to remove the front of the diff, I will do that.
But a sealant like RTV would be sufficient if not having a gasket is good to know, thanks :-)
Old Aug 7, 2016 | 05:49 AM
Yes you can pump the fluid out of the fill hole, however is it has not been apart in many years there will be some sludge at the bottom that cannot be cleaned out.
Old Aug 7, 2016 | 06:46 AM
Jandk's Avatar
I had no idea that sludge would be created in a diff... Then I will strongly consider not cutting corners, and do it the messy way and open it op. Thanks
Old Aug 7, 2016 | 07:34 AM
The old-style Olds/Pontiac axle doesn't have a cover. The whole center section comes out like on a Ford 9".
Old Aug 7, 2016 | 09:22 AM
citcapp's Avatar
Yes its a chore,
Have to jack up the rear, remove rear tires and wheels disassemble the rear brakes remove the backing plate, remove the rear axles, remove the drive line unbolt the center section and loosen to drain oil into a pan then remove rear. clean out the muck at the bottom of the housing and then reverse the process filling with new recommended oil usually 90 weight.
Things to check while you have it apart
brake shoes or pads
axle bearings and seals
pinion seal
replace above as needed
This can turn into a MAW in a hurry
Old Aug 7, 2016 | 10:41 AM
Sorry about the drain plug comment - I really thought I had typed fill plug.
Old Aug 12, 2016 | 07:42 PM
monzaz's Avatar
Not so much sludge just fluid evaporation so it looses it viscosity and becomes tar again....plus contamination of metal from bearings and gear which become a silt of sort. lol. too much heat will do that to oil.
Old Aug 13, 2016 | 12:54 AM
Jandk's Avatar
Okay, it makes sense. Thanks
RXN
Sep 20, 2014 05:04 AM
HiCompOlds
Drivetrain/Differentials
Jul 24, 2014 11:02 AM
delta_88_germany
May 16, 2013 04:15 AM
Wyze
Aug 26, 2010 01:54 PM
