How to identify a rearend without taking the cover off
Old Aug 26, 2010 | 07:34 AM
Wyze's Avatar
I have a 12 bolt in my 68 Cutlass and I'm trying to find put what kind it is!!!
Is there any way to tell without taking the cover off???
Old Aug 26, 2010 | 07:57 AM
wmachine's Avatar
Trying to remember member
Post pics. If it is the original, it would be an O type with a 10-bolt carrier and a 12-bolt cover.
Old Aug 26, 2010 | 08:08 AM
Run to Rund's Avatar
The 12 bolt cover for the O= Oldsmobile mfg. diff has a smooth center with a rounded bulge outward, and is smooth and flat between the mounting bolts, and has a lip at the outer edge. The Chevy 12-bolt cover is bulged but has a big V shaped crease running from the left axle tube area, toward the center and upward, then downward again to the area of the right axle tube. This crease is used to direct diff oil toward the axle tubes and from there the oil lubes the outer axle bearings. The C cover also has a rib between each pair of the 12 cover bolts in addition to the lip at the perimeter of the cover.
Old Aug 26, 2010 | 08:25 AM
I'll make this even easier.
Chevy 12 bolt:
Type O:
This page will also help:
http://www.supercarsunlimited.com/in...id/diff_id.htm
Old Aug 26, 2010 | 08:44 AM
Wyze's Avatar
Pics coming!!!
Old Aug 26, 2010 | 08:54 AM
Wyze's Avatar
Old Aug 26, 2010 | 08:55 AM
Wyze's Avatar
Didn't see the pics!!!
Thanks Joe!!!!
Old Aug 26, 2010 | 08:57 AM
Wyze's Avatar
Yeah this O type is confusing!!!
So it's really a 10 bolt????
Old Aug 26, 2010 | 10:16 AM
Many people assume that "10 bolt" and "12 bolt" refers to the back cover. It does not. It refers to the number of bolts holding the ring gear to the carrier. Coincidentally, on Chevy 10 and 12 bolt axles, the ring gear and cover bolts are the same. Other GM axles are not that way, but in this Chevy-centric world, everyone assumes that.
Frankly, I'm not sure what's so confusing. It's a Type O, which was installed by the factory on all A-body cars from 1968-70 (except those built in Canada). Once you know that, you just need to get parts for the Type O.
Old Aug 26, 2010 | 10:20 AM
Joe,
Don't you mean all A body "Olds" from 68-70 [except Canada] ?
Old Aug 26, 2010 | 10:36 AM
Originally Posted by Jamesbo
Joe,
Is there any other kind?
Old Aug 26, 2010 | 01:54 PM
greenslade's Avatar
would a 1973 --98 have a O type diff? the one in mine looks like the O type.
lemoldsnut
Sep 4, 2014 11:36 AM
dartphil
19
Aug 7, 2011 05:13 PM
Southern_Hospitality
Jul 28, 2009 08:03 PM
bigbrother
17
Jul 6, 2008 05:27 PM
silverriff
Mar 3, 2008 04:57 PM
