POSI Rearend -Corvette or TransAm
Old Jan 7, 2016 | 02:43 PM
BlueBeast's Avatar
Smile POSI Rearend -Corvette or TransAm
I have a 10 bolt GM rear end I picked up from a buddy who was going to do a one tire fire to POSI traction swap but ended up 86ing the whole project.
The rear end is a 10 bolt GM late 80's to early 90's Corvette or Trans Am POSI.
I am needing to know if this would work in my 1971 Cutlass, 455, TH400 (longtail) transmission with the 455 drive shaft, would it blow up or not even be usable. If it is doable is this something I can swap the pumpkin out to existing axles?
I haven't seen any posts regarding this, maybe I'm not looking hard enough.
Thanks in advance,
Old Jan 7, 2016 | 03:08 PM
It is not out of a Corvette if its not independent suspension.
Old Jan 7, 2016 | 06:10 PM
scottv442's Avatar
Maintained
X2^^^^
I would not bother using the 10-bolt unless its a 8.5" version. Most 80's cars had the 7.5" 10-bolt, at least in the G-body & F-body cars. Too weak for a 455 if you get traction under your wheels.
Old Jan 8, 2016 | 01:23 PM
monzaz's Avatar
rear
vette and trans am have totally different rears so what is the rear. Post pictures.
Curth
Sep 22, 2010 07:28 AM
reesejames
Jun 6, 2010 05:30 PM
copper128
Mar 6, 2010 11:32 AM
wash464
Aug 26, 2009 05:47 AM
DennisG.
Mar 22, 2008 06:20 AM
