12 bolt ?
Old Jun 21, 2017 | 07:26 AM
Maverick's Avatar
Dr.Olds Illegitimate Son
12 bolt ?
Did Olds have a 12 bolt available in an A-Body in '72 ?
I had one offered to me for cheap but didn't Olds had a 12 bolt .
Old Jun 21, 2017 | 08:37 AM
oldsmobiledave's Avatar
Fyi
Type O 12 bolt 1967-1970 on all American built Olds A body.
Canadian built 1964-1967 Olds A body was 8.2" BOP.
Chevy 12 bolt on all Canadian built Olds A body 1968-1969.
Corporate 8.5" on all Olds A body 1971-1972. No 12 bolt period.
Old Jun 21, 2017 | 09:07 AM
RROLDSX's Avatar
I assume a 12 bolt will still fit in a 71-72 A body?
Old Jun 21, 2017 | 09:21 AM
If it came out of a 68-72 A body originally, then yes it will fit a 71-72 A body.
Old Jun 21, 2017 | 02:13 PM
Fyi
A 65-67 narrow A body 12 bolt is also a bolt in replacement for a 71-72 but wheels will require more backspacing.
Old Jun 21, 2017 | 08:34 PM
Actually, the narrower axle requires wheels with less backspacing (the wheel mounting surface is closer to the inboard lip of the wheel). This is negative offset.
Old Jun 22, 2017 | 11:18 AM
Of course. That's what I get for posting on 3 hours sleep.
Thanks for the correction.
Old Jun 23, 2017 | 02:26 PM
monzaz's Avatar
actually
Actually Stock rims will not make any real difference swapping the 64-67 12 bolt..... ONLY if you have super wide rims and tires.
1/2" on each side will not make a difference with factory stock wheels rims etc.
What will be something you need to deal with is the 64 65 66 spring perch being flat. The 1967-1972 has the raise cup perch for the lower spring pig tail.
Then 12 bolt chevy will have different Yokes. 1310 u-bolt, 1310 strap and bolts, 1330 straps and bolts, Mechanics 3R BOP with u-bolts.
Jim
J D Race
tmcfall
May 29, 2024 12:41 PM
tru-blue 442
Drivetrain/Differentials
May 7, 2012 08:48 AM
72442conv
Mar 19, 2012 07:14 AM
olds4life
Oct 5, 2010 05:18 AM
dman0712
Mar 16, 2010 07:40 PM
